![]() ![]() ![]() Drives: 2007 Toyota Yaris S Sedan Join Date: Jul 2007
Can the Yaris handle 6psi with stock ECU, injectors and fuel pump?
If the Yaris can handle the 6psi of boost, i will be able to build the cheapest and simplest supercharger kit on the market today and be able to sell it to anyone who wants one. if it's just a matter of upgrading the fuel pump and using some slightly bigger injectors and letting the ECU do the rest. then i think i could really pull this off. the kit would comprise of a supercharger(duh!), an intake pipe from the supercharger to the throttle body, a BOV on the intake pipe and maybe bigger injectors and fuel pump(depending on the Yaris responds to 6psi stock). so, please let me know what you guys think.
![]() http://www.youtube.com/watch?v=YnTlNLz9Iqc http://money.cnn.com/galleries/2010/...le_cars/5.html http://www.subcompactculture.com/200...-miles-on.html |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
From what I've read on the Forced Induction forum; the stock fuel pump will definitely work and stock injectors should work as well. But I am by no means any sort of expert on the subject.
But I would be interested, depending on price, if it works. =) |
+1 stock pump/injectors should handle 6 psi. Just need a piggyback for the ECU.
Blitz supercharger blows 7 psi with stock injectors and fuel system. I ran an 8psi turbo set up with Scion tC injectors and stock fuel system otherwise.
![]() ![]() ![]() ![]() Drives: 07 Blazing Blue LB Join Date: Jun 2007
sorry to thread jack but just a quick question. Can the yaris ecu handle a 5-6 psi with no piggyback?
Most Satisfying Crew Serious Business... MunkyWurks Garage - 8088488794 |
Garm can answer that best, I believe he ran his car prior to this with 8psi on stock electronics with just bigger injectors.. Gave a couple CELs of course, but with lower boost you *may* be able to get away with it
I was planning to build a turbo kit but I don't want to bother with a piggyback management for now so I was planning to run a low boost for a while just to get the kit started.
Bathroom + Laptop = <3
Ughhhh since no one asked this yet.... What model supercharger, how do you plan on using a BOV and why would you need one? You're leaving alot to imagination and I hope you can provide some solid good answers! :)
I've been planning on making a turbo kit for a while, but it's been all talk and research research research until I'm starting to pull a few strings and get things together with my business. |
Honestly, I still think the Power Enterprise Supercharger kit is still the best one I've seen so far. far better than the blitz. This is only from videos I've seen from japan.
Speaking of which didn't someone on here get that kit? i think it was frownonfun or something like that.
yeah and then never updated anyone or anything and then Power Enterprise Evan went off the face of this earth... sounds like something shady went down to me!!! Hope someone knows if the guy(s) are okay
frownonfun got it finally, hes been working on translating the instructions from Japanese to English last I heard.
#13 | |
Start another Oil Thread!
i don't see how a centrifugal supercharger is "better" than a positive displacement SC.. but to each their own.
you nailed it sir.
I don't see why you would need to translate instructions from Japanese to English if its just like 10 parts... couple pipes, bracket, supercharger, what else?
#16 | |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
call me ignorant, but i've never heard a SC using a bov, wouldn't that defeat the purpose of the SC?
#18 | |
superchargers generally use bypass valves or butterfly valves. i wouldn't a BOV on a stock ecu'd car, especially if the bov is located between the MAF and throttlebody. you aren't delivering metered air to the engine, it's being vented to atmosphere.
you nailed it sir.
| Another S/C'd member worried about his AFR | LtNoogie | Forced Induction Forum | 181 | 04-18-2009 01:19 AM |
| Any body have good data on the Yaris fuel system? | LtNoogie | Performance Modifications | 9 | 03-26-2009 09:01 AM |
