![]() Drives: yaris Join Date: Mar 2009
Gauge Cluster Swap, other interior swap questions.
Is it a direct swap to the gauges with the Tach in it? Plug and play so to speak? Is the odo info stored in the gauges or in the ecu?
Also, is the car pre wired for power windows, so all I would have to do is swap all the stuff over? Sounds like a weird question, but i know most manufacturers run the wiring for everything so it's one less part to produce seperately. IE cars without fog lights often times are wired for them, you just need to install the lights themselves, which I am hoping is the case with the window motors. Same deal with the cruise control, is it wired, just needs the hardware? Any insight would be appreciated. Some is more curiosity for if I find a good deal, but the tach is a big thing right now as I want to start autocrossing and don't really want to install an aftermarket tach. Last edited by Adrenalingirl_K; 04-07-2009 at 02:21 PM. |
It's not plug and play. AFAIK, no one on here has been able to do it successfully. I think someone switched out a dash from a Canadian model, but then you have Kms for speed.
I looked at quite a few options, but settled on a small tach on the top of the steering column. I used a GlowShift that nearly matches the dash lighting AND I can still get into my driver side glovebox.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
the ODO is stored in the cluster.
and, do you really need a tach for auto-x ?? I don't think so. |
Yeah, you do, waiting till you hit the rev limiter to shift to second is a poor way to do it and waiting till the car leaves it's power band to wait to down shift is an even worse idea. Hell, I mean, if you just downshifted when it was slow, you would never find a gear low enough.
SIPNDEW
i just added and aftermarket tach
| FS: Authentic JDM TRD Gauge Cluster Tri Meter Cover | R0ME0 | Items for Sale by private party | 3 | 03-15-2009 09:13 PM |
| 09 Liftback Speedo Gauge cluster dilemna with picsŪ | pariahdecss | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 01-28-2009 03:04 PM |
| Gauge Cluster LED's | Kaotic Lazagna | Cosmetic Modifications (Exterior/Interior) | 11 | 01-08-2009 01:59 AM |
| Instrument Cluster Swap | thepaidtraveler | Cosmetic Modifications (Exterior/Interior) | 28 | 11-24-2008 10:53 AM |
| Canadian gauge cluster work in US Yaris HB? | heeroyuy01195 | Cosmetic Modifications (Exterior/Interior) | 7 | 08-25-2007 02:20 AM |
