![]() ![]() ![]() Drives: bone f*ing stock Join Date: Dec 2008
whats the caliber of my rifle?
5 points if you can guess the caliber of my new rifle, 500 points if you can guess what rifle =P
★weeaboo★
.223?
AR type rifle of some kind? |
![]() ![]() ![]() Drives: 2008 Yaris Liftback Join Date: Oct 2008
5.63mm AK
kekeke this is fun! PK is getting very close
Drives: 2008 Yaris Join Date: Oct 2008
actually I bought the Winchester SXR(autoloader)
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
#13 | |
If original, get a decent gunschmidt to check her out. Other than that, yeah - great guns. We used a set of Parker-Hale tweaked 303s in the rifle team at school, and it was possible to get a 10-inch grouip at 500 yards with service ammo. No bench, no bags, just what you Yanks call a Hasty Sling. Good times...
#15 | |
Later on studies showed that shooting people over 400 yards away was in general a waste of time, so planners reduced the mass of the ammunition and pushed up the pressures. I am not experienced with the Lee-Enfield and do not know about barrel fatigue issue. In US made arms such an effect is quite rare in 30 caliber and up rifles. It's common in the 22 caliber military stuff because water will "wick" into the barrel, causing it to split when it's fired. SMLEs were made in most of the bigger Commonwealth nations. If you're not sure about the rifle's origin it pays to have an experienced person check it out. I can almost guarantee it's been shot before, if only for Proof testing. The markings will appear on the barrel or receiver. Gene |
#16 | |
Approved shooting safety glasses can save you. The true phenomena when a barrel explodes and splits is where it happens internally. A barrel consists of lands and grooves. The lands being the high spots and the groves are cut into the conventional barrel. When it a barrel fails it is in the thicker area and not the thinner area. The pressure builds and reflects of the thicker areas with more velocity. Confused now? ![]() Here is a photo I took inside a "larger" barrel of a bigger gun!
some people are little slinkies. . . . .they are really good for nothing. . . .but they still bring a smile to your face when you push them down a flight of stairs. Come to the DARKSIDE..... We have candy ![]() ![]() |
#17 | |
"uring testing in March 1958, rainwater caused the barrels of both the ArmaLite and Winchester rifles to burst, causing the Army to once again press for a larger round, this time at 0.258 in (6.6 mm). Nevertheless, they suggested continued testing for cold-weather suitability in Alaska. Stoner was later asked to fly in to replace several parts, and when he arrived he found the rifles had been improperly reassembled. When he returned he was surprised to learn that they too had rejected the design even before he had arrived; their report also endorsed the 0.258 in (6.6 mm) round. After reading these reports, General Maxwell Taylor became dead-set against the design, and pressed for continued production of the M14." No, I don't know why this effect occurs. I do know that I was warned NEVER to shoot the rifle with water in the barrel. The "procedure" after fording water is to aim the barrel towards the ground and allow it to drain. Gene |
#18 | |
The bigger the barrel, the greater the capacity to survive this kind of abuse, since the amount of water per inch is a "unit" ratio, and the volume that can absorb the over-pressure is a "square" ratio (per inch of barrel). So, twice the calibre, four times the volume to absorb.
| Finish Sedan S Intake, Paint Caliber, Air Vent Lights | jamal1984 | Performance Modifications | 9 | 03-12-2007 11:57 AM |
