![]() ![]() Drives: 2008 Sedan White Join Date: Oct 2008
TPMS question
I made a tube with pvc pipe to hold the TPMS sensors that can be pressurised. I have all four in it. Put it by the computor, no luck, light is still on. Anyone have any ideas?
SIPNDEW
do the bypass.
OK, for another option. I got it to work today! Had a leak. I used a female cleanout adapter, an end cap, and a cleanout screw in end plug all in 3". Drilled a hole for one of the tpms sensor's valve stem into the endcap. Had to flush sand the end to get it thin enough for clearence to mount one of the sensors in the end of the cap. I glued the end cap to the cleanout, loaded all the sensors in it, and screwed the cleanout nut in with some special thread compound my friend had. (sorry don't know what brand, some kind of pipe thread compound in a paste form) At first it didn't work. Leaks through the threads. I just kept tightening it today uptil it quit leaking. Charged it up to 40 lbs. Light went out! Just another option to put out the light. Only disadvantage with this setup over the bypass is how long do the batteries last?
#4 | |
Still - its cool you found another way around it.. |
Oh, It cost less then 10 bucks. My frugal butt can handle that.
You should have seen the first one I made, it really looked like a pipe bomb.
This was easier than doing the bypass that I'll eventually be doing. |
I love momentum.
I give you major points for the idea!
Another thing to consider is putting all four sensors in the spare tire. I've heard of people having the spare drilled to hold all of them, and having it re-balanced. Apparently it works... |
Good idea there. No pipe bomb looking thing in my glove box.
| Tire rotation: Does TPMS recognize tire position? | jcdrotos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-17-2011 02:00 PM |
| TPMS Gauges - do they exist? | Sodium Duck | DIY / Maintenance / Service | 24 | 03-01-2009 12:18 AM |
| TPMS question | Cutie Pie #2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 01-31-2009 07:27 PM |
| So question here abt hatchs in general | Jem_hadar | General Yaris / Vitz Discussion | 12 | 01-06-2009 03:06 AM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
