![]() Drives: 2007 Hatchback Join Date: Mar 2009
kiwi or scangauge?
Hello everone I just found the kiwi plx one ebay for $85 + $8 very cheap.
Item 400043450156. I want to get one for my car, I have a 87 with no tach. Is this a good replacement for an aftermarket tachomerter?. Is it easier to install? or should I expend the extra money and get a scangauge. I looked around in the forum and it looks like this is the way to go for an after market tach. Any suggestions appreciated. |
#2 | |
Kiwi offers a real nice one for about 300.00, but it's geared mainly to those that want to get maximum mpg...it's designed to train you how to drive for that maximum fuel economy. |
Learn to Relax
If you just want a cheap, plug and play, tach, the KIWI can fill that need. If it's engine performance that you want, the Scangauge II would be much better.
Microimage sells the SG II. |
Looks like this unit has mpg and rpms and other things but will the connector work with 07 hatchback? is this a standard connector? Is the set up for this unit easier than an aftermarket tach?
* Fuel Used (Gallons, Liters) * Fuel Remaining (Gallons, Liters) * Distance to Empty (Gallons, Liters) * Engine RPM * Vehicle Speed (MPH, KMH) * Coolant Temp (Fahrenheit, Celsius) * Throttle Position |
#5 | |
The setup is much easier than an aftermarket tach, but the refresh rate is slower than a real tach.
I have a ScangaugeII and a tach. Tach is more responsive, scangauge is for the MPG's and all the other info like temps, pressures and such that aren't in the Yaris gauge cluster.
#8 | |
Drives: 2008 Yaris Join Date: Oct 2008
A Scanguage is so useful I suggested to my Toyota dealer that they offer them with each new Yaris and other economy car. They said that they'll "Think about it" which I consider a qualified "no". Having never used a Kiwi I don't know a thing about it. Gene |
| Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! | TRD_Yaris | General Yaris / Vitz Discussion | 183 | 02-01-2017 01:18 PM |
| WTB stock rims + tires + ScanGauge | Tonavi | Willing to Buy by private party | 5 | 12-26-2008 12:09 AM |
| scangauge II versions | TinyGiant | Fuel Economy Forum | 1 | 12-23-2008 01:10 PM |
| FS: Scangauge II (barely used) $80 | Fel | Items for Sale by private party | 25 | 12-09-2008 12:15 AM |
| PLX Kiwi | natethegreat38 | Fuel Economy Forum | 27 | 11-14-2008 11:57 AM |
