![]() ![]() Drives: 2008 Red Yaris LB Join Date: Nov 2008
Tach ECU wire, auto
I was just installing a tach on my yaris when, I realized that I didn't have the greenish blue wire on my OBD II port. I am guessing that an auto has it on a different wire. Can someone tell me which one is it?
Your best bet would probably be to swap to a manual transmission so you actually utilize a tach
no one knows, or have installed a tach on an auto?
Same position, but on my 09 it is beige:
I love momentum.
^ I used that same wire and it works great.
What should I set the tach to, I am guessing 4 cly. But when I reved it up in neutral, it went to 7K rpm. Just thinking thats kinda odd.
SIPNDEW
it does on mine too. why do do you even need a tach for an auto?
idk, just like to see whats happening and or if the auto is shifting dumbly
AD&D Dork
Drives: 07Liftback/07sedanS Join Date: Oct 2008
lol Im driven an auto and I put in a tach too
we may not need it for shifting but its still nice to see the RPMs for what ever reason. In my last car (also an auto) it had a stock tach, At one point I started having this misfire that would only occur between 3700 & 4300 rpm. It was a dead give away when I googled 'misfire' and the said RPM range. if it wasnt for the tach I wouldnt have been able to diagnose it myself, so IMO, tachs arnt just for shiftin
![]() Mods: K&N filter, Megan Coilovers, Ultra Racing 19mm rear sway bar, Sun tachometer, Window Tint. |
