Old 12-02-2006, 12:51 AM   #1
liquidx084
liquidx084's Avatar
Drives: 1985 Toyota Corolla GTS
HID Installation
I was wondering if anyone here installed HID's on their Yaris'. I'm going to be getting HID's soon and I don't want to go in guns-a-blazing and taking bolts off without really knowing where to mount the ballast. Pretty much, i'd rather not take the front bumper off if I don't have to. Though, by the looks of it that'll be unrealistic.
Plans: Complete restoration to paint and body, Work Meister S1 2P wheels, Project mu calipers, F20C AP1 complete swap with 6 spd transmission and ECU.
twitter: https://twitter.com/migueljay
liquidx084 is offline   Reply With Quote
Old 12-02-2006, 01:27 AM   #2
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
You might want to use the SEARCH function next time.
http://www.yarisworld.com/forums/showthread.php?t=515
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 12-03-2006, 11:14 AM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
No need to remove the bumper or headlight housings... unless of course, you are doing an Eagleye High/Low kit, as the bulb base is a bit longer then the standard low beam only kit.. hence the reason poping the headlight housings will make the install a bit easier.
Good luck.
Old 12-03-2006, 09:36 PM   #4
yuri2002
Drives: Yaris HB
HID on Yaris
Hi, for those who installed HID kit on their yaris, how's the beam pattern? I understand projector will produce wider and uniformed light spread. Does the kit give out hot spots on the ground? Also, how far is the light, shorter or same as OEM halogen light? Thanks
yuri2002 is offline   Reply With Quote
Old 12-03-2006, 10:15 PM   #5
Chris07LB
Chris07LB's Avatar
Search under my user name, I have posted many many shots of my HIDs... I would re-post, but on a different computer right now.
Old 12-04-2006, 08:14 AM   #6
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I don't know how people fit their hands behind the headlights - must have little girly-man hands.
It takes about 2 minutes to remove the 7 clips holding the top of the bumper - I use the smallest regular bit screwdriver in my kit - just push down the center then pull the whole clip out. No need to take the bolts in the bottom out. Maybe another three minutes to remove the six bolts holding the headlight housing in and you've got a lot more room to work.
Old 12-04-2006, 08:22 AM   #7
Violin
Violin's Avatar
This is what my Eagleye hi/lo kit looked like.
Old 05-07-2009, 06:44 AM   #8
Uaaurelia
Drives: Yaris RS Hatchback
anyone know what to do with the yellow wires for the halogen on the top, where to connect them too?
Uaaurelia is offline   Reply With Quote
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 03:05 PM
KLight HID Conversion Group Buy!! $165.00 shipped!! JRT lighting Sponsors Classifieds Area 4 11-20-2006 11:47 PM
Brand New HID conversion Kit H4 6000K JRT lighting Sponsors Classifieds Area 28 11-11-2006 03:24 PM
My 6500k H4 HID Review [pics] Chris07LB Cosmetic Modifications (Exterior/Interior) 74 10-10-2006 08:19 PM
