Old 05-03-2009, 12:26 PM   #1
Dbeau
Dbeau's Avatar
Drives: 2007 Yaris Sedan Aero
Tree Sap Issue ?
I got these darn tree sap spots that I just cant seem to get off.
I have tried several car cleaners including some bug and tar remover, but no luck. Stuff is hard as rock not tacky at all.
Anyone have had this problem and found a product or technique that works ?
Dbeau is offline   Reply With Quote
Old 05-03-2009, 12:32 PM   #2
Wet towel on a hot day. Lay it on the spot and leave it there for as long as possible. once it is rehydrated, use WD40 to clear it.
Old 05-03-2009, 12:40 PM   #3
Dbeau
Dbeau's Avatar
Suppose to be really nice day, lots of sun so maby I'll give the wet towel method a try.
Thanks
Old 05-03-2009, 12:36 PM   #4
frownonfun
frownonfun's Avatar
damn trees. i know exactly how you feel. i have these all over my yaris and my tundra. you know how long it takes to scrub that crap off a tundra crew max? anyway that's how i get the sap off mine, soap and water and a lot of scrubbing. it just takes a while. WD40 is probably a good idea though.
Old 05-03-2009, 01:46 PM   #5
andru47
andru47's Avatar
Drives: 2009 Yaris 3DR LB
Send a message via AIM to andru47
You can also try using some Toyo Guard Sealant Cleaner. It works wonders for me haven't had tree sap but this stuff can really take stuff off your paint job with little effort. Couldn't find a picture of the bottle to show you but, attached is a Photobucket album with videos of someone using it.
Toyo Guard Sealant Cleaner Link
My Yaris: The Azure
andru47 is offline   Reply With Quote
Old 05-03-2009, 02:02 PM   #6
goku87
goku87's Avatar
Drives: Black HB
Exclamation whatever you do, do it asap
This happened to my "other car" and i just waited a couple months to clean them off, and the spots where the sap was are permentantly "etched" in.
but a shot in the dark: try spitting on it before you scrub. the enzymes in your saliva might help break it down and make it easier to rub/washs/scrape/grind off.
goku87 is offline   Reply With Quote
Old 05-03-2009, 02:17 PM   #7
counterfiend
Drives: 2005 Ford Focus
or you could just claybar the car every few months, or not park near the tree's that give you the sap.
counterfiend is offline   Reply With Quote
Old 05-03-2009, 07:34 PM   #8
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
cut down the tree
just kidding
clay bar works best and won't wear down the paint like polishes or cleaners
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 05-04-2009, 02:46 AM   #9
goku87
goku87's Avatar
Drives: Black HB
Originally Posted by 07WYarisRS View Post
cut down the tree
thats what happened to my tree
Old 05-03-2009, 11:30 PM   #10
kenkyd
kanye
Drives: 11 Corolla S
Send a message via AIM to kenkyd
you have to put the sap/bug remover on the sap, let it sit and then rubrubrub. it doesnt take the paint off of my car when i do it that way, ive done at least 100+ spots on my car. i park under a tree everynight. but it always comes off
kenkyd is offline   Reply With Quote
Old 05-04-2009, 02:37 PM   #11
tomato
tomato's Avatar
"Whatever you do, do it ASAP"
I would agree with that. My Honda had some tree sap on the side, didn't notice it right away and never could get rid of it after that. The only thing I didn't try was claying the car, though. That might work. But if you wait too long, the stuff goes right through the paint and you got a permanent stain there.
Old 05-04-2009, 04:58 PM   #12
TroyD
Drives: 1996 Toyota Corolla (170K!)
Use ZEP Grafitti Remover. It'll take it right off with suprisingly little effort. (This is harsh stuff though so don't get it on any plastic or rubber parts)...and don't forget to re-wax, since it will strip all the wax off too.
I got my Corolla from some people that apparantly had left it parked under a pine tree for about 8 years of it's life, and it was COVERED with pine pitch some of which had hardened on for years. The ZEP stuff took it right off. Although it admittedly took some effort on the thicker older patches, and the clearcoat was pretty much shot underneath once I got the sap off.
TroyD is offline   Reply With Quote
Old 05-06-2009, 02:29 PM   #13
Tobyz28
Drives: 2009 Yaris 5dr Black
I've tackled serious tree sap issues in the past with my black camaro. Paper towel and Rubbing alcohol. Be very careful, use a light touch to remove it.
2009 Yaris LE 5dr (Stock and Shiny)
1995 Camaro Z28 Convertible (All boltons)
Tobyz28 is offline   Reply With Quote
Old 05-06-2009, 03:32 PM   #14
Nagoya_TRD.
Drives: None.
Soap, water, and claybar.
Nagoya_TRD. is offline   Reply With Quote
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 09:04 PM
Weird issue during braking xtremesniper Canada 21 06-04-2009 12:00 PM
CONSUMER REPORTS : MARCH issue reviews '09 YARIS . gid General Yaris / Vitz Discussion 93 01-06-2009 05:10 AM
Stupid pre-lit Christmas tree... SIPNGAS Off-topic / Other Cars / Everything else Discussions 26 12-01-2008 08:38 PM
Tree 1 - Yaris 0 gabagooo General Yaris / Vitz Discussion 19 04-25-2007 06:24 PM
