XBL: Jeemee Ghost
Today I figured I install my tanabe df210s today. weather isn't on my side and is on the verge of a downpour, but I'll work in the rain if I half to.
I've ran into numerous problems just taking off the front stock suspension. I started on the driver side and ended up having to take the wiper assembly out and all the metal shrouds due to lack of tools I suppose. Anyways, I cant seem to get the top strut nut off, at all. Won't budge. Everything I have tried hasn't worked. If I keep up trying I'll end up striping everything out. Any help would be greatly appreciated!!
_________________________________________________ Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers |
Have you had a read of this .
XBL: Jeemee Ghost
man I have read both DIYs. I see a good impact being the only way. Both DIYs said they did it with a open box end and a 6mm hex. But my bluepoint wrench couldn't get that angle even with the wiper assembly removed and the black shroud. Both the wrench and hex were slipping and SAE stuff wouldn't fit properly either. I can understand how to do it, but I can't figure how the fuck to do it, lol.
I have given up today, but if anyone has any tips on how to do this easily please let me know. Anyone in central Arkansas on here? Know of anyone with an impact or maybe a more vast selection of tools?
XBL: Jeemee Ghost
Step 14 =
_________________________________________________ Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers Last edited by Jeemee; 05-01-2009 at 06:44 PM. |
Reluctantly Crouched...
Make sure you aren't trying to remove the spring top nut, it isn't supposed to be removed until the strut is out of the vehicle. Remove the 3 smaller nuts. I think the larger center nut might be spinning the strut rod anyway, so it might not back all the way off. Either way, you DO NOT want to release all that spring tension while the strut is still on the car. Very bad. If you follow the DIY, the Yaris struts should be one of the easiest removals out there. The rear is even better.
XBL: Jeemee Ghost
You know, you just may be right! Can anyone clarify this, as it's not really that specific in the DIYs. Are the two nuts, one holding the top of the strut in place and one holding the spring. This is how I assumed it was. It very well may be only one nut, and it's hold the spring.
You know, I never thought of that! Let's make me feel stupid shall we lol
#7 | |
It's one nut.
#8 | |
XBL: Jeemee Ghost
Yeah, no offset wrench, but do I need to loosen the nut first, or will it come out without? I removed the shroud so I could reach it but it would not budge.
Here's a quick list of what I did Took wheel off. Took nut off of sway bar link. Took off both lower strut bolts and nuts Took off wipers, assembly, and shroud Took off brake line nut Took off dust cap on top of strut (a 17mm nut stared up at me and laughed )Here's a quote from the "Tanabe" DIY: Quote:
[QUOTE]It's one nut./QUOTE]
Crap. I mixed-up my Yaris w/ my Miata. I've changed struts/spring on both in the last couple of months. Sorry about making things even more confusing. |
Are you holding the shaft with an allen wrench while you loosen the 17mm with an open-ended wrench or offset box?
Also, you can get an affordable/decent offset box wrench set (metric) for $10-$15 at your local Auto Zone or Wally world. Well worth the investment. |
XBL: Jeemee Ghost
Yes. 6mm. Started to slip before it broke loose (allen key not wrench).
super duper M*******TOR
Drives: 2007 jahPANIS egg(Sarao Phil) Join Date: Oct 2008
need to take off the top nut bolt first to remove it...u could buy a cheap $30 lighter operated impact wrench at kragen or autozone...03z33 and i were having the same problem yesterday and he decided to buy those cheap impact wrench...sucker works like magic..
XBL: Jeemee Ghost
Thanks!! Question about impact: Pneumatic or Electric?
XBL: Jeemee Ghost
If there is only one nut (assuming it holds in the spring) do I need to loosen it to remove the strut assembly from the car? At which then I'd compress the springs for an easier removal of course.
XBL: Jeemee Ghost
Oh and I have a 18v Makita Impact Driver. A buddy has it right now. It puts out about 100ft/lbs of torque I believe. Think that will get it done?
12v electric impact wrench
struts have two bolts...one on top that holds a plate to the car and the second one will b the one holding the spring down...we did not decompress the springs...we held the strut down pointing to a safe direction and used the impact wrench....have fun! |
![]() ![]() ![]() ![]() ![]() Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
i was having hell getting that nut off also... it broke loose fairly easy with some quick taps on the wrench with a rubber mallet. i say taps but really i had to hit it pretty hard. just make sure the wrench is on good.
#18 | ||
XBL: Jeemee Ghost
Thanks again!
I'd like to thank everyone for the fast responses. I was a little worried about the speed as of my last post of my exhaust (been only a few posts and it's been up over 24 hrs lol) I will attempt once again tomorrow unless weather says no. If I run into any problems I'm sure everyone will hear from me again. Glad I decided to tackle the hard part first lol
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| Non-Yaris Audio install help needed | Revsson | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 08-17-2009 11:47 AM |
| spring install help asap! DELETE | tristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 02-18-2009 01:30 PM |
| TANABE DF210 Spring Install [pics] | Chris07LB | DIY / Maintenance / Service | 148 | 07-16-2007 09:26 PM |
