Old 05-08-2009, 11:35 PM   #1
Taiyaki
アキバ製
Taiyaki's Avatar
Getting new wheels, but need help
Ok so I dont know much about wheels, but Im planning on getting 15x6.5 and each is about 15lbs (i know alittle heavy) and thinking dropping on NF210s.
Will I get any rubbing? Also idk what "offset" is, I tried to learn what all them numbers mean but just went threw one ear and out the other. but the offset is 38.
They also said, that they recommend buying tuner lugs. idk what they are but do i need them?
Old 05-09-2009, 08:44 AM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
15x6.5, ET38 will be fine. 15 lbs. is not a heavy wheel. You will need new (tuner) lugs. NF's provide a moderate drop and rubbing issues should be minimal if any with the correct tyre size on that wheel.
Which size tyre are you planning to install?
Old 05-09-2009, 11:50 PM   #3
Taiyaki
アキバ製
Taiyaki's Avatar
They recommended getting the same brand lugs as the wheels to insure fitment, But could I get different ones as long as its the same size? its says "forged, 12x1.5mm" So any 12x1.5mm will fit?
I just started to understand how to read tire sizes but don't know what size will make it rub. I hope to have 0 rubbing. So I'm guessing that the sidewall % is what will determin if it will rub or not right? So I will need 165/__R15. Can someone help me fill in my blank. Haha thanks
Old 05-10-2009, 03:45 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
165 is the tire width, but it's too skinny for the Yaris. Stick to 195, a good standard width.
The "/__" should be 50. Since the wheels are 15", there isn't much out there. 50 or 45 (if you can find 45.)
Dropping on Tanabe NF210 with this tire size should have 0 rubs unless you hit some of the many massive Oahu potholes.
Old 05-10-2009, 03:56 AM   #5
Taiyaki
アキバ製
Taiyaki's Avatar
the wheel only comes in 15"x6.5. So I need to get 165 right? Or could I get 195? Yeah I just don't want to rub when I fully turn.
Old 05-10-2009, 04:13 AM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
A 195 width tire would fit a 15x6.5 rim just fine. (on NF210 springs)
The factory tire size on your car is 185/65/15, correct?
If you don't have any rubbing problems now with 185 width, don't get a tire that's even skinnier that your stock tires.
If you're looking to save some money, you could put the stock tires on your new rims and have no rubbing problems
Old 05-10-2009, 05:08 AM   #7
Taiyaki
アキバ製
Taiyaki's Avatar
My stocks are 14". So what should the middle number be? 195/__/15
Old 05-10-2009, 05:13 AM   #8
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
middle number = 50
Old 05-10-2009, 05:20 AM   #9
Taiyaki
アキバ製
Taiyaki's Avatar
ありがとうな~
You live on Oahu? Do you know the cheapest place to buy tires? Costco?
Old 05-10-2009, 05:44 AM   #10
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Yes, Oahu. Cheapest place? Depends on the kind of tire. Cheapest tire? Probably Federal tires (a Taiwan company). Discount Tire in Mapunapuna has a good stock and they mount & balance. Sometimes other shops like Titan sells during closeouts, but I don't know if they mount/balance. Last time I went to Lex Brodie, they had Falkens for $85 and mount/balance was included in the price. This was for the 195/50/15. You can always check on FH (forumshawaii), CL (craigslist) or HT (hawaiitalks) and look for some good deals there, too.
Old 05-10-2009, 05:56 AM   #11
Taiyaki
アキバ製
Taiyaki's Avatar
Oh cool I'll go check them out once my wheels come in.
Old 05-10-2009, 06:20 AM   #12
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
go rons performance they sell good tires the stickier the better for grip in dry and wet i recommend hankook rs2s or kumho asx and run a 195/50/15 the 45s might be to harass if you going drop to stiff thats why but 50 is the common size for this size rim you could even runa 205/50/15 or a 185/50/15 depends on where you want the lip sheilded by the tire or not
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 05-10-2009, 07:22 AM   #13
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
^if you do go Ron's talk to dave (mechanic) about changing out your tires. I had him put the tire pressure sensors on my new rims.
808_Yaris is offline   Reply With Quote
Old 05-10-2009, 08:28 AM   #14
kimona
kimona's Avatar
With the NF drop and those new wheels (15x6.5, ET38), install 195/55/15's. That's it. Period.
Old 05-11-2009, 04:20 AM   #15
Taiyaki
アキバ製
Taiyaki's Avatar
also they said its best to get the same brand lugs to insure correct fitment. They are 12x1.5mm. Could I just get any lug as long as its 12x1.5mm?
Old 05-11-2009, 04:24 AM   #16
808_Yaris
Where is Oahu?
808_Yaris's Avatar
i'm sure that you can go with any lug nuts. i have gorilla lug nuts and they are just fine..
Old 05-11-2009, 04:30 AM   #17
battleversiontc
yo where you buying your rims from cause normally they send lugs and stuff with em
Old 05-11-2009, 04:35 AM   #18
808_Yaris
Where is Oahu?
808_Yaris's Avatar
tire rack is pretty good :) they give lug nuts too!
12/20/08 Buddy Club USA 5th Anniversary Clearance SALE DuckinOut California 3 12-18-2008 01:25 AM
Black powder coat my wheels? vacantj Cosmetic Modifications (Exterior/Interior) 7 09-03-2007 02:56 PM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 09:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 07:55 PM
