Old 10-13-2009, 01:09 PM   #1
yarr_is
Drives: yaris
DF210 Q's
Tried searching... couldn't find the answer I need.
Tanabe DF210 owners. How long are you guys been running these springs? Do they get bouncy afterwards? How low and especially living in LA where road sucks how daily drivable are they? How well they side with GF series?
http://www.tanabe-usa.com/df210.asp?id=1
I'm looking to do spring and strut combo also. Has anyone gone to this route? If so what struts are you guys running?
Thanks
yarr_is is offline   Reply With Quote
Old 10-13-2009, 01:27 PM   #2
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Im just running the DF210 Springs, they still hold their own, and ive driven on some pretty bad streets before. they are driveable here, not really sure how it is in LA.
Its a Chao!!!
Old 10-13-2009, 01:44 PM   #3
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
LA = Pothole City (especially after rainy season)
I'm looking for springs myself. So far all the ones I've looked at seem promising. Now it's just a matter of finding the best deal and coughing up the $$
Old 10-13-2009, 02:40 PM   #4
yarr_is
Drives: yaris
Yeah it's such BS how so many construction going on here and nothing seems to be improving. Looks like things are getting worst. Potholes everywhere. I've bent wheels just hitting them. I run coilovers on my other car and reason I want to go springs on yaris cause of this. Coilovers and stiff set up isn't friendly here. Makes me hate just driving full suspension set up car here in LA
Old 10-13-2009, 03:05 PM   #5
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
bouncy comes from the struts not the springs
Originally Posted by xnamerxx
you nailed it sir.
Old 10-13-2009, 04:38 PM   #6
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
If you are concerned about bottoming-out, serious rubbing or uncomfortable ride, then I'd stay away from the bigger drops (2" or more) and stick with 15" wheels to give more tire-suspension. also, try to stay 205 or narrower to give the best tire clearance.
Tamago is correct; bouncy is bad or soft struts, not the springs. Bad springs just get weaker and sag or bottom out more easily.
Old 10-13-2009, 05:15 PM   #7
Tamago
Tamago's Avatar
Drives: ZZW30
and the tanabes are the KING of sagging.
you nailed it sir.
Old 10-13-2009, 10:07 PM   #8
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
Like Tamago said
Konigs Feathers 17x7 with Toyo Proxes4 215/40/17
Tanabe DF210
Stock shocks
Rear seat removed
No struts of any kind
I've had my Tanabe DF210 for 2years now. They're racked up to 40k on them. Due to the sagging I was forced to remove the rear seat to level out the wheel gap.
Now it's about 1.5 gap on both front and rear. Prior to rear seat removal my rear fender had no gap and I was dealing with a lot of fender rubbing on turns. With the current set up the only rubbing I have is on high speed turns (Looping freeway on-ramp for example)
I don't know if you noticed the Rear fender is lower/longer then the fender in front. For my car it's roughly 24.5inches from ground to peak of front fender and 24inches from the ground to peak of rear fender.
eijikikimaru is offline   Reply With Quote
Old 10-14-2009, 12:21 AM   #9
SilverBack
Joey
SilverBack's Avatar
So I guess the DFs are out of the running
Which springs would you suggest for us, Tamago? Coilovers (for any of us who can afford it)?
There was a section of road a few blocks from my house that was too big to even call a pothole. It felt like a 2 inch drop straight down (I actually ran out there with a ruler once) followed by 30 feet of very rough ups and downs with almost no pavement. It ended with a 3 inch sharp jump back to normal asphalt. It was finally repaved over the Summer after years of wear and tear. At the same time other roads are quickly becoming bad too, and you just know they'll never get to it until half the town loses their strut bolts and bushings.
To top that off the 10 freeway's been getting overnight "repavements" too. It was just fine until CalTrans touched it this year. Now it feels like you're driving a lowrider.
It's almost tempting to not even get the car lowered...
Old 10-14-2009, 10:40 AM   #10
MUSKOKA800
MUSKOKA800's Avatar
Springs support weight. Shocks/struts control motion.
Upgrade your dampers when moving to stiffer springs or be prepared to pogo. Nothing looks more pathetic than a slammed ricer pogoing down the freeway.
Old 10-14-2009, 12:00 PM   #11
Tamago
Tamago's Avatar
Drives: ZZW30
i suggest Eibach.
you nailed it sir.
Old 10-14-2009, 12:55 PM   #12
You have a PM.
Old 10-16-2009, 12:40 PM   #13
yarr_is
Drives: yaris
thanks i got it... I'll check you out
Megan Racing Springs V. DF210 Springs... E dot Rio Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-18-2009 11:21 PM
Tanabe DF210 Springs in GTA hafeez Items for Sale by private party 9 04-19-2009 02:30 PM
WTB: DF210 gwasabi Willing to Buy by private party 2 03-16-2009 12:24 AM
NF210 and DF210 lowering springs? jaserhunter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 02-15-2009 09:36 PM
df210 OxyG3nE Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 08-15-2006 07:04 PM
