Old 05-07-2009, 07:20 AM   #1
The Shape
Drives: 2007 Yaris Sedan
Which mark on engine oil dipstick?
I changed the oil recently on my wife's yaris and with a new filter put in about 3 3/4 quarts of oil. The level on the dipstick is above the crosshatched area it covers the F on the stick. Is this to much will it damage the engine??
The Shape is offline   Reply With Quote
Old 05-07-2009, 10:02 AM   #2
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
That is just a little bit over, so I don't think it will do any real damage. But you may find that your mileage is 2-3Mpg lower than usual.
Run it for a day and check it again.
If it is still over the top mark, simply undo the plug only enough to let it drip (do not remove) after 30 seconds or so, wipe the outlet with a clean rag and tighten the plug fully.
For the little bit that you might be over, it may not be worth the trouble to try and drain off the extra 1/2 quart. The first gen Scion xB has the same size motor, and I know some people just put in a full 4 quarts into it with a filter change without even thinking about it.
SpaceShot is offline   Reply With Quote
Old 05-07-2009, 10:12 AM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
i put 4qt and it goes just right at the top of the cross.
the thing is, when you do it on your driveway, it depends on how your car is angled. I always put mine angled backward, so oil drains out without leaving a "lake" inside the pan.
I usually let it drain while i go eat lunch, and then come back later to finish the job. :P
jetedit: shouldn't the 1nz-fe take a full 4qt?? ie, 3.7L
Old 05-07-2009, 10:17 AM   #4
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Spaceshots right, chances are that it wont damage the engine but it will slow it up just a bit. Just remember that too little is WAY better than too much!
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 05-07-2009, 12:29 PM   #5
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I don't think you have to worry. Next time, put three quarts, run the engine and check to see how much you need to add. I usually put 3 1/2 quarts to reach the full mark.
Old 05-07-2009, 03:52 PM   #6
hatchbackkid82
Drives: .
Is your dipstick plastic or metal? Let me stop before i get banned, the dipstick subject is very sensitive around here.
Old 05-07-2009, 04:55 PM   #7
2006fronty
2006fronty's Avatar
Drives: 2010 Mazda3 iTouring
I hate my plastic dipstick, can I replace it with a metal one? What if the plastic breaks and gets in my engine? HAHAHAHAHAHAHA
Old 05-07-2009, 05:06 PM   #8
hatchbackkid82
Drives: .
Awwwww man your asking for it Can i put wings on my Yaris? Remember that one or better yet; What's a pulley?
Old 05-07-2009, 07:01 PM   #9
IllusionX
10 years already with the 1nz-fe. I don't recall anybody having the plastic stick breaking apart and falling into the oil pan.
Old 05-07-2009, 07:30 PM   #10
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
I think that happened to yaris t-sport, not sure what he did to get it out.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-08-2009, 11:49 AM   #11
b_hickman11
Drives: 08 Sedan
There was someone on here a while back that had their dipstick break off inside of the engine......not for sure who that was though
b_hickman11 is offline   Reply With Quote
Old 05-17-2009, 10:23 PM   #12
2bad4u
Drives: 06 Toyota Vitz RS
Vitz RS comes with a metal dip stick
2bad4u is offline   Reply With Quote
Old 05-18-2009, 11:19 AM   #13
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
My 3 Yarises and the Echo before them all have metal dipsticks. He must've gotten a special one.
leaky seal on engine? oil overfill? jeff69dini DIY / Maintenance / Service 23 06-07-2010 01:52 AM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-24-2009 12:30 AM
Which side of engine oil dipstick do you read ? Yawesh General Yaris / Vitz Discussion 11 01-08-2009 04:43 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
