Old 05-19-2009, 04:31 PM   #1
kudzu71
Drives: 2007 Yaris hatchback
Send a message via AIM to kudzu71 Send a message via Yahoo to kudzu71
JBL Amp question
Hey guys.
I'm planning on putting one of the OEM nav units in my 07 LB. I read that I need one of the Toyota JBL amps in order for it to work. There are several available on ebay from various Toyota models. My question is does it matter what model the amp came from? They all look pretty much the same to me.
Also does anyone know if the OEM nav unit will work with the factory aux jack? I've read the DIY that explains how to connect it via RCA to an aftermarket deck, but I'm hoping the Toyota nav deck will just automagically work. I guess that would depend on how old the deck is right?
Okay so that is 2 questions.
kudzu71 is offline   Reply With Quote
Old 05-19-2009, 04:53 PM   #2
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
I'm surprised to hear a nav unit needs an amp to run. But I'm not familiar with the OEM one. As far as the amp though, if you really do need one it shouldn't matter which one. Any amp with enough wattage to handle what your installing will be fine.
Old 05-19-2009, 05:53 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
i'd like to know which toyota navi unit you are getting....
Old 05-20-2009, 11:17 AM   #4
kudzu71
Thanks for the info. I was looking at one like this one:
Ebay link. The auction ends soon so here is the basic info on it:
Toyota Model # 17006, Part # 86120-35240 with a MFD August 2002
There is another auction for a newer model, Part # 86120-08160 that looks about the same.
I'm gonna pass on that auction until I understand what all I need for it to work in my car. They turn up on ebay fairly regularly.
Here is the post explaining why I need the JBL amp.
navigation post
Old 05-19-2009, 06:21 PM   #5
severous01
some nav units have special wiring and no amplification. if he gets a regular jbl amp and tries to install it the low voltage wire harness may not fit right. also, the wiring instructions for factory should have the compatible amps that go with it.
Old 05-20-2009, 10:29 AM   #6
staticorex
staticorex's Avatar
Ahh. That makes sense. If that's the case he prolly does need the specific amp. Interesting.
Question about amp wiring Arkhangel In Car Entertainment + Electronics (audio / video / alarm) 8 03-17-2009 10:26 PM
Amp And Cable Kit Question Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 13 01-28-2009 07:59 PM
Quick advice needed on unfinished amp install GreenSpeed In Car Entertainment + Electronics (audio / video / alarm) 15 01-16-2009 12:03 AM
A question about amp construction Sodium Duck In Car Entertainment + Electronics (audio / video / alarm) 1 10-31-2008 08:48 PM
amp wiring question... Keymaster In Car Entertainment + Electronics (audio / video / alarm) 3 02-03-2007 11:01 AM
