Old 05-20-2009, 09:45 AM   #1
vten
need guidance for the compustar 2W900FMR install
http://www.compustar.com/products/2W900FMR.htm
I just got the compustar 2W900FMR remote start with the FT-5000AS module . anyone can help me with the install or a DIY ?? I also bought the door actuators with the 2 wires.....
a local store quote me $350 for the install above....
thanks guys
Old 05-20-2009, 10:02 AM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
It just so happens that I'll be at the shop today prepping for, if not actually installing, my Autoppage RS1000 alarm...
While I'm not familiar with the ideosynchracies of the Yaris in an alarm install yet, I have good people around me that know a hell of a lot more than I do...
With that being said, I can have them look at the questions you have about the install if you'd like. So, throw some questions my way and I'll see if I can answer them.
― Thomas Paine
Old 05-20-2009, 10:16 AM   #3
vten
thanks sqcomp,
I need the wiring guidance for the specific alarm if it's possible so I can save a little $$ for another project .
I search a couple diy alarm/ remote install on the forum, but I just want to double check beforehand.
thanks a lot.
Old 05-20-2009, 12:28 PM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I think I can get you the diagrams...
Give me a couple hours or so.
I'm going to assume you have an... 09 3 door?
This may also help for right now:
http://www.etimago.com/yaris/repairmanual/
― Thomas Paine
Old 05-20-2009, 03:33 PM   #5
I installed an UltraStart remote starter and a in my 09 5 door (and we put a Valet in SodiumDuck's 08 3 door at the same time). I was going to put together a DIY, but never got around to it. My 09 had the engine immobilizer, so I use the Fortin KEY-OVERRIDE-SL2 transponder key bypass module (which doesn't require a sacrificial key).
Let me know if you have any questions.
Here are a couple of threads with info:
Keyless Entry DIY:
http://www.yarisworld.com/forums/sho...anq+diy+remote
Correction on Lock/Unlock Wires:
http://www.yarisworld.com/forums/sho...9&postcount=18
Old 05-20-2009, 07:03 PM   #6
vten
it's a 08 3dr , manual everything...
thanks guys for helping me out ....I really appreciate it ...I have all day tomorrow to install the alarm and the door actuator ( 2 wires one ) ....I wish my universal power window would be here too so I can do it all at once ...
Tan
Old 05-20-2009, 08:43 PM   #7
vten
......bare with me here:P ....
on the door actuator with 2 wires .. one dark green and one dark blue ....where are they supposed to connect ??
Old 05-20-2009, 09:09 PM   #8
Green is lock, blue is unlock. They require positive pulses and typically draw too much current to drive directly from a remote starter/keyless entry system.
Here's an example of wiring for them. The lock and unlock pulse connections would go to the appropriate terminals of the remote starter/keyless entry system.
http://www.commandoalarms.com/doorlockactuators.pdf
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
