Old 05-29-2009, 06:46 PM   #1
naossoan
Drives: 07 Yaris 3DR
I CANNOT get the front strut nut off
I'm trying to install my TEIN springs. I got the back done easy peezy. I've got everything off the front necessary to access the front strut bolts with the alan key inside and 17mm nut.
I CANNOT use a box wrench to turn it, it just starts to stip the upper part of the bolt. I CANNOT use a ratchet with a socket to loosten it because I need the alan key to hold the centre from moving.
How the bloody hell do I get these nuts off? The spring install guide makes it sound easy peezy but that just is NOT happening.
Does anyone know if a socket with a hexagonal outside (instead of completely round) exists? You know then I could use the socket and use a large like 19 or 21mm box wrench to turn the socket...
OR anyone have any other teniques?
Thanks
naossoan is offline   Reply With Quote
Old 05-29-2009, 07:24 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
remove the top panels plastic and steel , wiper's then use a impact gun
electric or air powered , also make sure you are turnning the nut counter clock wise
Old 05-29-2009, 08:17 PM   #3
naossoan
I dont think you understand what I mean, I've already done all that.
But I got them off I went and bought some better vice grips.
Old 05-29-2009, 08:20 PM   #4
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
You need a 17mm off-set wrench. It's the only good way to get that nut off.
17mm wrench and the correct allen wrench, then it will come off.
Old 05-29-2009, 08:33 PM   #5
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Agreed.
DerFlosser is offline   Reply With Quote
Old 05-29-2009, 08:53 PM   #6
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
If you are trying too remove the first nut on the strut , do it while there is upward pressure on the strut ,
ie with wheel on and sitting on the ground or with jack under wheel hub ,
this takes some of the pressure of that nut .
if you are talking about the secound nut use spring compressor to take up spring pressure , of nut .
Old 05-29-2009, 11:17 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
What thirtynine said. I used a offset wrench and a allen key. I used a small pipe on the end of the allen key to hold it in place and a long handle offset box wrench. Came off with a little effort without having to remove the cowl.
Old 05-30-2009, 06:05 AM   #8
ddongbap
http://www.craftsman.com/shc/s/p_101...Mechanic+Tools
YUMMIEEEEEEe.
Old 05-30-2009, 03:27 PM   #9
naossoan
ok thanks guys.
I eventually got them off by using some vice grips with a 17mm socket and a alan wrench...
I have another problem now though. I'll make a different thread though as it's a totally different problem.
I'll have to pick me up some wrenches.
Old 05-30-2009, 03:31 PM   #10
^ correct answers, offset box end wrench FTW, or air tools.
Old 05-30-2009, 04:11 PM   #11
naossoan
Think these or these will work?
I can't buy something online and wait a week or something to get it, I need the tools now...and you'll see why from this thread.
Tanabe Front Strut Bar Benggolf2 Performance Modifications 57 08-15-2014 03:41 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 12:52 PM
Any difference on Tanabe front Strut Bar VS Unknown ebay Strut Bar? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-07-2009 07:58 PM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 02-22-2007 12:08 PM
C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 01-10-2007 07:53 PM
