Old 06-24-2009, 07:11 PM   #1
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
New brake pads and noise
So I got some carbotech pads and this is my first brake pad change I've attempted. Before I changed the pads I was getting some squealing noises when I was barely tapping the brakes. Regardless of the noise, I wanted different brake pads anyways. So I installed the carbotech pads and put some lube stuff on the back of the shims. Then I go out to "bed" in the brakes. I hear some squealing on my right wheel ONLY when I press down super hard. I know there is a break in period for new pads and a proper "bedding" of the pads are required. However would this same noise be related to the noise with my old pads? My old pads didnt seem very worn out and the rotor seems to be in good condition. Should I wait a while till my pads are broken in or could it be something else?
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 06-24-2009, 07:12 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
could be dirt or maybe the 'Squealers' are out of place? can you snap some pix?
Old 06-24-2009, 07:45 PM   #3
eii
Rides canyon walls
eii's Avatar
I can take pics tomorrow, I'm just getting over a fever right now and I'm super tired. Just pics of the rotor is what you need? I'll go over the pad install again tomorrow and clean a little more to see if that helps. I dont have to drive anywhere tonight so it'll be ok till tomorrow.
Old 06-24-2009, 07:52 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
probably a bent backing plate
Old 06-24-2009, 08:35 PM   #5
supmet
Drives: 2007 4 Door Yaris
Did you lube all contact points? The sides of the pads where they slide in and out?
How hard did you bed them in? I talked to carbotech and they said you should smell the breaks, and maybe see a little smoke. I definitely smelled mine when I did them. And once they are properly bedded, that's all the breaking in they need.
Also it sounds like you didn't change or turn your rotors. Take them off and down to a machine shop and they'll turn them for around 20 bucks. Give those new pads a fresh surface to work with.(if you turn them now you'll probably have to rebed them, but I'd call carbotech to make sure)
Old 06-24-2009, 09:10 PM   #6
Henry G.
Drives: 2008 Yaris HB
The Yaris brakes suck I try not to use them.
Has anyone noticed an increase in braking performance with the carbotech pads and was it just resistance to fading or initial feel and performance?
Henry G. is offline   Reply With Quote
Old 06-25-2009, 01:52 AM   #7
eii
Rides canyon walls
eii's Avatar
Yeah, I've read it maybe the rotors reguardless if they LOOK ok. However the right side was significantly dirtier than the left, so that may be it. I'll go over everything you guys said.
Old 06-25-2009, 05:45 AM   #8
eii
Rides canyon walls
eii's Avatar
I drove a bit and no noise till the brakes heated up and it started to squeal again. hrm..
Old 06-25-2009, 10:49 AM   #9
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
You didn't reface the disks? There'll be a pretty long breakin period till the worn surfaces of the disks take on the wear pattern they get with the different pad material.
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 05:23 PM
CarboTech brakes in stock cali yaris Micro Image 20 07-28-2009 04:50 PM
Parking Brake Adjustment Q's Lafiro DIY / Maintenance / Service 3 04-13-2009 08:19 PM
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS kargoboy YarisUniverse 11 01-20-2009 04:43 PM
First thoughts: Carbotech XP8 pads and slotted rotors jkuchta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 12-19-2008 10:21 AM
