![]() ![]() ![]() Drives: Yaris Join Date: May 2009
New Product: Penguin Garage Rear Camber Shims!
Hello YarisWorld!
Penguin Garage is pleased to announce a low cost rear camber solution for the Toyota Yaris! * Works with Penguin Garage Hub Spacers as well as unmodified Yarii * Adds around 1 Degree of negative camber to the built in factory alignment specs (varies by amount of lowering, etc) * made from 316 Stainless Steel * Precision machined to clear hub pilot diameter and add uniform camber Each kit includes: 4 camber shims (two each side) to be installed between the lower hub bolts and the spacer (or axle in stock applications) Pricing: Camber kit alone, $15 shipped to any US state/territory (out of country buyers please PM for very reasonable rates!) Camber kit if purchased with a set of rear hub spacers, $PM for Special Pricing to all of our previous customers who have already purchased spacers and want the extra clearance gained by these washers, PLEASE PM US for your special pricing! ![]() (note, spacer and bolt not included )
What's the difference between that and buying some washers and cutting them like that?
Is the material different?
We released these so you guys don't need to modify them to the correct size.
these are all the same, so no worries of modifying,testing,modifying,testing and so on. Just slip them in and enjoy the added camber. (Professional alignment suggested). |
Garm, these are stainless washers. We didn't go exotic on the materials to help keep costs down.
Thanks. I think that helps our customers.
![]() Drives: xd Join Date: Dec 2008
pmed
Reluctantly Crouched...
Query: I recently tried the plastic camber plates/shims and they didn't really work-out very well, so I'm exploring other options. I don't really need to add more negative camber, but I really want to eliminate the factory toe-in. I'm not rolling over the rear tires, even in hard cornering on concrete, and the car rotates reasonably well. I don't mind if I get a little more negative camber, but that's not a priority. Is there a configuration with these shims that will achieve zero or VERY slight negative toe-in?
Second, if I have my current alignment numbers, can we calculate fairly-precisely the degree of adjustment that will be made to each side? |
Received my shims a couple of days ago. Getting them installed tomorrow.
Thanks for the great service!
Finally got these installed... Got a chance to drive around a bit, and I like the new feel, although somehow my suspension is sitting a bit too high at the moment... I guess that will pass after a couple of days.
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
these came free with the spacers right??
how come they cost now, just wondering.... I suppose if you only want the shims it would make sense.... I never installed them because I was unsure of the uneven surface that would be caused by adding them.... what would be cool is if you made angled shims and adjacent shims that would let the hub sit flat on them instead of there being a gap. still, thanks for making this stuff for the yaris, Im really loving my PG13's and cant wait for some new wheels to really see the more flush look :D
-Jen <3 ![]() Quote:
| installing Penguin Garage rear hub spacers! | Tamago | DIY / Maintenance / Service | 101 | 05-21-2011 01:29 PM |
| Adjusting rear camber?? | PHXDEMON | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 63 | 10-23-2009 01:11 PM |
| Penguin Garage Rear Hub Spacers!! | Penguin Garage | Sponsors Classifieds Area | 92 | 09-02-2009 07:16 PM |
| Penguin Garage Rear Hub Spacer Raffle!! | Penguin Garage | General Yaris / Vitz Discussion | 27 | 06-30-2009 02:05 AM |
| Urgent Peanut Product Recall | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 5 | 02-08-2009 02:03 PM |
