Old 05-31-2009, 12:09 PM   #1
millsn
Drives: Yaris diesel
Yaris diesel predetonation?
I run a Yaris diesel and wondered if anyone else had one (I'm in the UK). My problem is that the car always sounds like it has some level of predetonation or "pinking". The toyota dealer can find nothing wrong but the car is not right. At times power falls away inexplicably.
Has anyone had a simiolar problem and found the solution?
millsn is offline   Reply With Quote
Old 05-31-2009, 04:34 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Diesels are very different from gasoline. Detonation is caused by compression which the diesels rely on for combustion, no spark plugs. Diesels produce a lot of torque at low RPM and they are not high revving. The power will drop off after 3500 RPM? Most likely the injectors will cut off.
Old 05-31-2009, 07:20 PM   #3
auxmike
auxmike's Avatar
A Yaris diesel, why?
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 06:06 PM
Would Americans Buy a Diesel Yaris? Would it Sell Well in North America? gabagooo General Yaris / Vitz Discussion 23 12-11-2006 10:51 AM
