Old 05-28-2009, 09:34 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
front end damage mystery
I hit some loose gravel last week on the front right with my Hatchback,07.
I made a major racket. Ever since I have a knocking sound in the front but no one has been able to ID the problem yet. It sounds like the soft knocking of a loose muffler but the
mechanics say nothing is loose and they were underneath it in a service pit.It also has a similar knock to a bad water pump bearing but no change yet in water temp. via scan gauge.
It seems to lessen when I press on the gas. There is also some tinny metal scraping off and on which I think might be a broken shock but the car doesnt look crooked at all.
The sound is in the front.
Anyone have an experience with something similar.???? thanks
yaris9876 is offline   Reply With Quote
Old 05-28-2009, 10:12 PM   #2
SailDesign
Drives: .
Stone in the hubcaps?
Old 05-28-2009, 10:13 PM   #3
kngrsll
Apexing Egg!!
kngrsll's Avatar
when did your boat turn blue? and why?
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 05-28-2009, 10:58 PM   #4
Check the front brake shield on that side.
Old 05-29-2009, 09:11 PM   #5
yaris9876
another mechanic couldnt see what it was but said it sounded bad. Anyone have a link to pics of the motor mounts on the hatchbk. I might have broken one..You cant see anything
on these micro rigs....
Old 05-30-2009, 01:29 AM   #6
silver_echo
ekodrvr
silver_echo's Avatar
where in the usa are you? if you are close to some of us that spend time under vehicles, then we could take a look under there, maybe with a comparison to a "known good" yaris... that will probably be what it takes to make the final diagnosis unless that mechanic that you took it to is blind...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 05-30-2009, 01:37 AM   #7
supmet
Drives: 2007 4 Door Yaris
Hitting gravel = broken motor mount?
I was picturing an inch or two of gravel on the ground - now I'm guessing you ran into a large pile.
There are about a million places gravel could lodge itself or damage in a car to make noise. Diagnosis over the internet is improbable.(at least without pictures and a much better explanation)
Old 05-30-2009, 01:47 AM   #8
hachi-roku_fan
Drives: 1986 Toyota Corolla
You might have a rock lodged in your tire tread.
hachi-roku_fan is offline   Reply With Quote
Old 05-30-2009, 09:34 AM   #9
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
Pull off your front tires and check behind the brake rotor, I get rocks in mine all the time. It makes a horrible noise.
Old 06-01-2009, 06:00 PM   #10
yaris9876
the car shudders when its started. Maybe Schwab can figure it out.
Old 06-02-2009, 05:00 PM   #11
yaris9876
it turned out to be a stone about 1.5 inches wedged between the transmission and the frame. It really made the car shudder when started.Now its fine.yee haw.
Old 06-02-2009, 05:13 PM   #12
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Holy crap, good find!
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 11:43 PM
Front end mask RocknRollRon Items for Sale by private party 7 09-02-2007 07:12 AM
Bra or front end protector? Yaris S N9QGS Cosmetic Modifications (Exterior/Interior) 6 07-13-2007 09:29 AM
FT: Polar white Front End in So. Cal Walter Items for Sale by private party 33 01-16-2007 01:11 AM
For trade, polar white front end Walter California 0 01-09-2007 12:38 AM
