Old 06-07-2009, 07:20 AM   #1
iggypops_1
Drives: 2009 sedan
rubber inserts
Just purchased a 2009 silver Yaris sedan with only 9 miles on it. Options include: automatic, power package and fog lights for $14,452 (out-the-door). I found 2 rubber inserts in a clear plastic bag located inside the glovebox. Does anyone know where these things go???
iggypops_1 is offline   Reply With Quote
Old 06-07-2009, 07:24 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
A pic would be handy,do these rubber plugs look like drain plugs for the floor pan? or door plugs that were taken out to install power windows?
Old 06-07-2009, 07:36 AM   #3
iggypops_1
Drives: 2009 sedan
They rubber plugs are approx 1 ½ inches by a ½ inch wide. The instructions on the plastic bag say “to pre-delivery inspector. Insert these rubber plugs into the holes of the center floor side member extensions.”
Old 06-07-2009, 07:44 AM   #4
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Uh-oh. Those plugs were supposed to be inserted to prevent your Toyota quality from leaking out.
Old 06-07-2009, 08:05 AM   #5
Forrest
Drives: 08 LB BLACK
Your dealer should have put them in appropriate areas that have holes that need to be plugged. There was a lot of posting done on this but not sure of name of topic. Take back to dealer and have him insert them.
Forrest is offline   Reply With Quote
Old 06-07-2009, 09:29 AM   #6
Yes, those are the floor drain plugs that get popped in under the carpet. They should have been installed during the pre-delivery check. I have had a couple of Yaris as rental cars and each one has had them sitting in the glove box. I guess that shows how well the dealers do the pre-delivery inspection. If they are not installed, water from the road can splash up and soak into the carpet.
Old 06-07-2009, 09:36 AM   #7
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Can someone post a pic of these? And maybe a pic of the underside of the car with them installed?
Old 06-07-2009, 09:58 AM   #8
I just took at the pre-delivery service doc and it mentions installing the plugs (Torque Box Drain Plugs), but doesn't show pictures. In the collision section of the service manual, the torque box looks to be under the driver's and passenger's floor area.
Looking under my car there are two sets of drain plugs, both of which are simply popped in from underneath (i.e. no carpet pull is required).
Here are pics of both:
Old 06-07-2009, 11:46 PM   #9
b_hickman11
Drives: 08 Sedan
They go underneath the car. Get on the ground and look in front of both rear tires. You should see an empty hole(1 on each side). Put the plugs in the holes.
b_hickman11 is offline   Reply With Quote
Old 06-08-2009, 03:44 AM   #10
tristan
it's been a while
tristan's Avatar
Drives: 2009 liftback
yeah i don't know about the sedan, but on the liftback they go in front of the rear tires
http://www.yarisworld.com/forums/showthread.php?t=9802
tristan is offline   Reply With Quote
Old 06-08-2009, 09:02 AM   #11
guzziknight
guzziknight's Avatar
Drives: 2008 Yaris S
I found the same rubber plugs in the glove box of the used 08 I bought. Now I know where they go. Thanks!
It does make you wonder what else they skipped on the pre-delivery inspection...
guzziknight is offline   Reply With Quote
MY RUBBER BAND BALL! AGHHH!!! Sodium Duck Off-topic / Other Cars / Everything else Discussions 47 03-06-2009 01:56 AM
rubber protector sheets? enobmort42 Cosmetic Modifications (Exterior/Interior) 0 02-25-2009 10:41 AM
WTB:Stock rubber Pedals or other pedals KSIbucky Willing to Buy by private party 3 02-23-2009 08:28 PM
Rubber plugs in glove box cfiimei DIY / Maintenance / Service 5 01-06-2009 04:48 AM
Stock rubber for sale GabL Items for Sale by private party 10 11-02-2008 09:39 PM
