![]() ![]() ![]() ![]() Drives: Thndr cl metallic HB 3 drs '05 Join Date: Mar 2006
Painted Lamps
Just as a hint if anyone wants to do this to change a little bit the look of your car here are some ideas any other idea just post it i'll be posting more soon
20 years... alive and kickin'!! ![]()
I stay G'd Up
i was soo waiting for that, check out my topic on them.
wanna know something that makes them look 100% better? 3m HIDB headlight film, i swear it makes them bounce out at you. its what I have on my headlights. |
![]() Drives: Vitz Join Date: Apr 2006
Canadian Echo Club: http://www.echo-bb.com |
Around the universe...
Drives: Uber-Evolved Pokemon Join Date: Jan 2006
Pascal's insane custom HID setup...so pretty...
Podiatrist
Drives: Turbo IS300 Join Date: May 2006
I say, throw an HID retro in there. It'd have to be a bi-xenon projector though.
Looks like those bulbs are H4 style. |
#6 | |
Yarii Hunter
Drives: 2007 Yaris Liftback and S13's Join Date: May 2006
it's an Infiniti Q45 xenon projector setup..very cool and good light output... I'm REALLY DIGGIN' the painted headlight housings..it's just the PERFECT amount of dark color to bring out the "dark chrome" accents of the reflectors!!! What temperature / how long did you "bake" your headlamps to get the seals to pull apart??? I got some work to do this week!! |
Podiatrist
Try 225 for 15 minutes.
Has anyone actually pulled their headlights on their Yaris?
I bought paint etc for painting out my lights but I cant get them out, seems like the front bumper has to come off or something. Theres bolts galore and clips.... hopefully someone has or has time too... or even breakaway drawings for any of this. |
#9 | |
![]() ![]() ![]() Drives: '07 Yaris Liftback Join Date: May 2006
many times you have to take off the front bumpers of cars to get to all of the bolts or take them out
'07 Yaris Liftback -Red 5spd w/convenience |
Thats kind of what I thought, I got the top bolt, the one right behind the grill and thats it its stuck. If you pry the fender liner out to look in behind the lens has a tab that hooks under the bottom edge to the front bumper but no bolt... strange. I was amped to paint.
#12 | |
Yarii Hunter
I just read all that in some of the posted PDFs -
There doesnt seem like an easy way or even remotely easy way of removing them. The great thing I found is that if you do it when the temperature is high outside the glue around the lens peels off by itself, without having to cook the lamp in the oven. |
#14 |
Drives: VITZ Join Date: Jul 2006
Hmm nice setup with that Infiniti Q45 xenon projector setup,
i'm wonderin how much that projector itself will cost?? any1 can help? |
#15 | |
Yarii Hunter
E to the B to the A to the Y!!!!!! it will cost about $400-800 (depending on how long you wanna wait for a good deal) for the Infiniti Q45 headlights (make sure to get BALLASTS!!!!) . if you're lucky the bulbs/ballasts/relectors(projectors) will be in great condition. After removing your Yaris headlights, pull apart the old reflector from the headlight housing. Then, it's just a matter of making a bracket (s) to mount the new Q45 projetors(relector) where the old Yaris reflector was. Reseal the Yaris headlight housing COMPLETELY, or they will fog badly and possibly burn out HID bulbs quickly. Wiring should be pretty simple, though you will want to consult an electrician to verify you're not pulling TOO MUCH CURRENT. just because it only pulls 35Watts compared to halogens running a standard 55Watt doesn't mean you're not gonna blow fuses or burn wiring harnesses.
Thanks for all the help over the years, YarisWorld!!!
#16 | |
Yarii Hunter
what is this 3M HIDB headlight film stuff you're talking about?
#17 | |
![]() ![]() Drives: Yaris Join Date: Jun 2006
These can be installed on headlights with halogens but it is not recommended to use it on headlights with real HIDs...because it creates an overheating, in consequence, reduces your HIDs' lifetime. |
#18 | |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
