215/45/17 on stock suspention ,want to verify
Hey guys,
Finally getting some new wheels for my '07 Sedan Looking at some 17" but im thinking of running 215/45/17 Nankang tires I Dont see those measurements on the list in the guide All Input welcome and appreciated |
toyota
its good!
most likely rub, depending on your offset
ok so more info needed??These are the Wheels Evoke 17 x 7 +40 offset
wow, $350 shipped for 4 new 17" wheels?
hmmmmmmmmmmmm (where's Russel teh Pirate???) maybe try 205 45 17?
so you think 215 will rub?
im thinking of 215 cuz i like the wider tire
215/45/17's on stock suspension should work okay, but you may get a little rub up front lock to lock. Problem is, they'll poke out up front on ET40 and won't look like a proper fitment. I'd stick with OEM size 205/45/17.
ET40??
You indicated an offset of +40mm.
Gotcha ;)
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
the higher the offset the less chance of rubbing. +43mm is the minimum offset to run in these cars to prevent rubbing lock-to-lock, over bumps, or on lowered suspension. I'm on a quest the find the lightest wheels that are +43mm or higher in 16x7.
#14 | |
and in the grand scheme of things, does 3mm really make THAT much difference?
#15 | |
With 205/50/16 rubber, you can generally run +42 safely with no up-front poke and no rubbing. With 195/50/16, you're generally safe with +38. To answer Tamago's question: Yes, a couple of mm's makes a significant difference on these cars. |
#16 | |
Also, OEM 16's don't exist, 15's or 17's only. What is the width of the +51 offset OEM wheel? I'm guessing 5.5 or 6 inches for the 15's and 6.5 for the 17's??? |
#17 | |
14x5, ET45, 175/65/14 15x5.5, ET45, 185/60/15 16x6, ET51, 195/50/16 17x6.5, ET51, 205/45/17 TRD Option 18x7.5, ET42, 215/35/18 |
I have 17x7" with an offset of +40, and 205/40/17 tires. I'm lowered on S.Tech springs, and get minimal rub on freeway dips. I don't get lock-to-lock rub tho, which is strange, but I'm not complaining.
| Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 12:30 PM |
