Old 08-28-2009, 04:50 AM   #1
Odd Metallic Sound From The Engine Bay
Please read my description and if you have any idea what it may be, don't be afraid to share. Thanks. Oh, and please listen with headphones.
http://www.youtube.com/watch?v=ovJ7O37oCfg
You'll hear the metallic sound at or around 4k rpm.
Old 08-28-2009, 06:02 AM   #2
lunjiaow
lunjiaow's Avatar
Drives: Yaris
You tried checking under your vehicle for any damage or for loose/bent metal, like exhaust hitting chasis?
lunjiaow is offline   Reply With Quote
Old 08-28-2009, 06:09 AM   #3
Took it to Toyota right after the incident. They inspected it, and nothing was damaged. It was not a thorough inspection, but more of a visual inspection. Hitting the block did cause my right fenderliner to rip off and hang on for dear life (had to replace it anyway, and 90 bucks for a piece of plastic!!!!?).
I don't see anything unusual either when I change my oil.
Old 08-28-2009, 12:00 PM   #4
2009BBPliftback
2009BBPliftback's Avatar
I would guess heat shield as well .. I had that happen to me on an accord v6 we used to own same sound..
2009BBPliftback is offline   Reply With Quote
Old 08-28-2009, 12:19 PM   #5
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Mine is doing the same thing when i am taking off. Its probably something in the exhaust loose or as someone posted earlier a loose heat shield cause mine sounds like it is coming from right under the passenger side where the exhaust is.
slvryaris is offline   Reply With Quote
Old 08-29-2009, 04:03 AM   #6
Oh, cool. So no one thinks it's anything major. I'll check the heat shield tomorrow. Thanks guys.
engine bay cleaning PhasedWalker DIY / Maintenance / Service 9 06-25-2009 01:04 AM
weird sound when engine at around 2000 rpms soup1207 DIY / Maintenance / Service 38 06-05-2009 11:01 AM
How would you sound deaden engine compartment? Yawesh General Yaris / Vitz Discussion 11 01-11-2009 04:41 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
Engine bay prettification project eTiMaGo Cosmetic Modifications (Exterior/Interior) 14 04-23-2007 05:22 PM
