Old 08-30-2009, 01:30 AM   #1
rexseesyou
Drives: 2009 Toyota Yaris Sedan S
Red face Video bypass?
I recently purchases the Eclipse AVN4430 double din head unit for my Yaris and was wondering if anyone knew how to do the video bypass while driving? I read that the other Eclipse AVN head units only require you to ground the brake wire. Does anyone know if this is true? Thanks.
rexseesyou is offline   Reply With Quote
Old 08-30-2009, 08:33 AM   #2
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
I don't know of any current models that still allow that simple hack. Hopefully yours is. Here's a pricey hack from everyone's favorite... E-Bay!
http://cgi.cafr.ebay.ca/Eclipse-AVN-...3%3A1|294%3A50
RUFFSTUFF is offline   Reply With Quote
Old 08-30-2009, 09:37 AM   #3
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
how would the head unit know one way or the other? There is a wire somewhere attached to the shift column. find and ground that wire.
If you can post a diagram of the harness for it.
Old 08-30-2009, 01:08 PM   #4
RUFFSTUFF
HU's got a little more complicated that the simple ground the parking brake sensing line a few years ago... even so there may be a few that that will still work on... I think the common method now looks for a transition from parking brake on to parking brake off. Grounding the wire would just give the condition of parking brake off. Some hacks involve splicing in a switch to toggle to fake the HU out... others use a monostable multivibrator (i.e. 555 timer) to trick the HU.
Old 09-01-2009, 03:02 PM   #5
rexseesyou
Thanks. I'll let you know what works when I get the chance to install my HU. Just wanted some tips first.
Old 09-01-2009, 11:00 PM   #6
AlexNet0
AlexNet0's Avatar
if you can post the wiring diagram for your head unit I can tell you one way or another.
Old 09-03-2009, 09:08 PM   #7
rexseesyou
I found this thread and the guy said he just grounded the parking wire to disable it...
http://www.solsticeforum.com/forum/f...0p-pics-55013/
Old 09-03-2009, 10:55 PM   #8
AlexNet0
AlexNet0's Avatar
lol thats what I said.
Old 09-06-2009, 06:41 PM   #9
nypunk
I don't wana be new again
Drives: 07 Flint Mica Sedan
I have a pioneer avic in my car and all I did was connect a toggle switch to the cable that should connect to the ebrake and at the flip of the switch video on video off
Ahh To Be A NOOB Again
nypunk is offline   Reply With Quote
Old 09-06-2009, 07:20 PM   #10
POORSHA
POORSHA's Avatar
Drives: 2008 LB
the new avic software reads the gps and will not let you watch while driving.
POORSHA is offline   Reply With Quote
Old 09-06-2009, 11:15 PM   #11
RUFFSTUFF
Which model? I know the older ones let you do that.
Old 09-07-2009, 10:45 AM   #12
POORSHA
POORSHA's Avatar
Drives: 2008 LB
avicf900bt
bypass, eclipse, installation, stereo, video
