DIY Fog Light Parts .
When you purchase any after market YARIS fog lights ,ie Sedan or Hatch Back
You should also purchuse or make the following parts These will allow you to PLUG into the factory wiring (no running wires through firewall) (must have) PURCHASE FROM Micro Image - cali yaris The relay goes under the dash as per diagram , (must have) PURCHASE FROM Micro Image - cali yaris If you want to use the aftermarket switch supplied you must remove it from the wiring loom supplied so it looks like the photo, then wire it in as per other diy's (or you can PM me and i wil send you the factory instructions) Or you can go and buy the factory light stalk and do no wireing in the cabin. just plug it in . (optional ) Last edited by 1NZYaris1; 03-28-2009 at 11:22 PM. |
Thanks for this info, I've been thinking of getting some fogs.
The above parts are a must have
Im waiting on this kit to get here
Does that harness look like what your sayin?
![]() ![]() The difference between fiction and reality? Fiction has to make sense. --Tom Clancy |
The harness in these Kits need to be modified if you want to plug into
the factory wiring, thats why you need to make & or buy the above parts . Otherwise you can use the kit wiring but you will need to find a way to run the wiring into the cabin. The Choice is yours |
Got it
I see so with this mod the fog lights will come on when you turn on your lights and no need for a special switch?
#8 | |
the end result by useing factory wiring is the dash symbol for fogs also turns on , and sounds light alarm if they are left on with car turned off . |
Ahh i see what you mean. I didnt even know there was a dash symbol for fogs lol.
im bit dense right now lol
what cable is that Labeled C Is there a better datailed how to??
C is the negative (earth ) factory diagram shows it connecting to the battery.
Still dont get it, ok i got the kit today and well wanted to connect it "Factory"
how can i hack / splice / wire the harness that came with the kit to achieve this?
PM'ed , but as above you need to purchase or make the above parts in photo's .
if you look at your photo of what you bought the loom on the left goes under to bonnet and connects to the lights , then make or purchase the red wires in my first photo . that is what connect you into the factory wiring. inside the cabin take the wiring loom on the right in your photo , take the plug that connects to the on/off switch follow the wires back as far as you can and cut them of the loom (as per photo 3 in my first post) now depending on how you want your lights to work , will depend on where you put those wires |
#14 |
ok understanding a bit more. lol i was like
#15 |
yeah, I'm still like that and I sell the kit.
#16 |
You 2 are shocker's , or is my spelling and english that bad . ![]() oh well you could always pay my airfare over , and i could teach you . ![]() better still you could come too New Zealand , for your a Holiday , and bring me a bonnet and front bumper and i will teach you .
#17 | |
#18 |
Bears eat beets.
Drives: Yaris LB Join Date: Aug 2006
I didn't see anything on your site for an 09 Hatchy... did I miss it??
Free veggie starter kit! |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 01:59 PM |
| DIY - fog light install | kurokoma-kun | DIY / Maintenance / Service | 3 | 09-18-2012 01:52 AM |
| Rav4 and Highlander fog light parts | 1NZYaris1 | Items for Sale by private party | 5 | 02-13-2009 11:43 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 11:42 AM |
