![]() ![]() Drives: 05 Echo H/B Join Date: Jul 2009
Snow Tires!!!!!!!
Currently I have a set of 205/50/15's on my Echo H/B that has TRD Lowering springs installed. I can't seem to find any 205's in a snow and was wondering if a 185/60/15 would fit on the car? It is a factory tire size!
Idea's??? |
a bit taller than your oem running stock, but should be fine
185/60/15 is the stock size for my Yaris sedan.
Last fall I picked up some winter tires on steelies which were 175/65/14 (stock Echo sizing). The Echo's 14" set-up stands a full inch shorter than my 15's. I made it through last winter (we had lot's of snow) but dragged bottom often. I'm looking for 185/75/14's to put on these wheels for the coming winter. If your Echo originally rolled on 14 inch stockers then 185/60/15 should work but are taller, which might be beneficial in the deep stuff but kill the off-the-line performance.
#4 | |
Any other size sugestions? If the 185/60/15 is taller should I go to a 55 series? |
Yea that is what I was thinking! Since its a factory size tires the 185/60/15 I might be ok! It will handle like crap I bet :(
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
Seems you guys are going against what works. Narrow section, high profile for snow: 165 or less, 70 or more. Make that tire cut into the snow rather than plow it! My neighbour's Model T with no snow tread goes ANYWHERE in the snow; tire section is really narrow, diameter really large, leaves 4x4s far behind...
I wish I could run those sizes.... I only have 15" wheels to run in the snow! I thought about running a 175/65/15 but not 100% sure if it will fit with no rubbing / turning issues.
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
Just pony up the extra $160 or so for a set of cheap-ass 14" steel rims if you're buying seperate winter tires, then buy really GOOD winter tires and only use them once the average daily high temperature drops to 60 or less. Block off your upper grill on your Yaris when you put the tires on too.
Sure, it'll cost about $570 for the whole package, but remember that set of tires should last 3 seasons or so, and it'll only be $400 or so after that since you'll have a set of dedicated rims for your winter tires. I'm doing that with Bridgestone Blizzak WS60's, the Michelin X-Ice series is better for dry traction, but nothing comes close to the WS60's for actual on-the-ice and deep-snow traction on passenger cars like our Yaris. =^.^=
![]() Last edited by WolfWings; 09-30-2009 at 12:47 PM. |
#11 | |
TRIM HUNTER
#12 | |
#13 | |
![]() ![]() ![]() ![]() Drives: 09 3dr LB MT Join Date: Aug 2009
2009 3dr LB MT Meteorite Metalic. Car bought 8/7/09. Now over 89k miles of trouble free driving, other than user error!!
Yea that would be the best option to drop down to a 14" wheel setup! I am going to steal the fit wheels and do a test fit! The downsides to being lowered :(
ill have some 14's im digging out of storage at the end of the month...
TRIM HUNTER
fit wheels will work. a guy by me has them on his black liftback....
Hm. There's another hint: steel wheels don't go nuts in the salt. I have a set of cast Jag wheels, they didn't see much salt, but they corroded far more than the steelies after many winters.
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 07:58 PM |
| 195/60/15 Snow Tires | beeboy1917 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 09-06-2009 03:58 PM |
| Tall thin Snow tires for 14" rims | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 07-25-2009 09:40 AM |
| Snow tires - Really worth the money? | 33OH | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 42 | 01-19-2009 05:11 PM |
| Snow tires | Phaeton | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 10-30-2008 09:43 PM |
