Reluctantly Crouched...
HID brightness question
Can anyone think of a reason why one side would be brighter than the other? I just installed a Xenon Vison bixenon HID kit, and it looks good, but I'm pretty sure the Right side is less bright than the left, particularly on the Hi-beam. Is this something that could be caused by a better ground on one compared to the other?
loose connection on the right side maybe? ballast not properly grounded? bulb not seated properly?
I'll do some checky-checking after dark, when I can be more definite about the intensity. Thanks, as I wanted to see if that was possible with HID's, or if they was basically "all-on" or "all-off" and the only fault could be a bad ballast or bulb. My right-side ground is not bare-metal, where the left side uses the battery-to-body ground point.
im thinking its the ground...i did that one time w/ the hid's on my matrix xrs....fixed the ground and everything was fine.
| HID question | 33lam | Cosmetic Modifications (Exterior/Interior) | 1 | 08-23-2009 05:54 AM |
| HID kit 2009 sedan question | 47_MasoN_47 | Cosmetic Modifications (Exterior/Interior) | 6 | 08-18-2009 06:26 PM |
| HID Question!! | MurderCivic | Cosmetic Modifications (Exterior/Interior) | 4 | 01-21-2009 04:29 AM |
| HID question | Sway84 | Cosmetic Modifications (Exterior/Interior) | 5 | 06-08-2007 11:17 AM |
| HID question | abdiel hiram | Cosmetic Modifications (Exterior/Interior) | 3 | 02-02-2007 01:28 PM |
