![]() ![]() Drives: 07 Mazda MX5 Copper Red Join Date: Jun 2009
New rims on the way! Mounted Today!
Pics uploaded!
![]() 17x7 +45 Team Dynamics ... ![]() I have some 205/40 hankooks on the way also. Currently on the stock suspension with a 12mm rear hub spacer. I have tein springs to install and hopefully no clearance issues!
Brent Former Yaris Owner Last edited by Brentorius; 10-02-2009 at 09:39 PM. |
#2 | |
Start another Oil Thread!
congrats! TDR's ftw! but 205/40 is kind of short IMO.
you nailed it sir.
only 7mm shorter than stock. I was originally thinking about the 195/45, but tires available in that size are limited.
I used to have a set of TDR's on my miata (15's) and liked them a lot
Brent Former Yaris Owner Last edited by Brentorius; 09-24-2009 at 02:12 AM. |
#4 | |
215 45 17 should fit fine with that wheel spec. where did you buy the TDR's by the way?
you nailed it sir.
#5 | |
I almost got a set from: http://stores.shop.ebay.com/Magik-Wheels__W0QQ_armrsZ1 - sells TDR and ships from Ca. Once I install the tein springs, there will not be too much room... The offset is high enough I might go for a 205/45 next time
Brent Former Yaris Owner |
Please post up pics once they are installed i been looking at these same rims
#7 | |
What the Pho?
Drives: '08 Meteorite Metallic MT LB Join Date: Oct 2008
Those are the same ones i want to get except in 15's.
Excellent wheels. Your Yaris will look outstanding with those wheels!
Who said Yaris was slow?
What's the weight on those 17's???
I know these on 15" are just above 12lbs Those on bronze would look killer on my car.... I haven't seen 17's TDR's on goodwins... anyone know if they carry them? |
#11 | ||
http://www.good-win-racing.com/Mazda.../21-10017.html
you nailed it sir.
Should be 16.5 lbs <from TD website>
those look REALLY good.
Beast
dam those Team dynamics are spreading
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
Reluctantly Crouched...
205's are a good call. The 215's are likely to rub with your springs, at least a little. I have 215/40/17 on 17x7 w/ +40 offset, and they rubbed with a 2" drop. No problems now that I'm on NF210's, but only a bit over 1" drop.
Apexing Egg!!
i love my team dynamics... i really like that i could get the +25 offset. i could use another 5mm spacer in the front when i slot in some more camber, and the rear hub spacers when i get stiffer rear springs, but other than that, they fit pretty good. mildy aggressive shall we say.
ill probably buy another set for R888's eventually.
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#17 | |
aren't you glad you're the first :) sorry the bandwagon took off but i'm still glad you went the route of TDR's instead of konig or others...
you nailed it sir.
#18 | |
![]() Pic from 2005:
| Tags |
| tdr, team dynamics |
| Need Help! with Tyres and Rims for my Sedan | seemeno | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 07-16-2009 05:37 PM |
| FS Brand New Stock rims w/ Tires | FlintS | Items for Sale by private party | 10 | 09-24-2007 09:22 PM |
| Need help when ordering my tires and rims | thomasward00 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-26-2007 10:40 PM |
| FS: 07 yaris RS stock rims n tires | thegame11 | Items for Sale by private party | 5 | 04-15-2007 02:25 PM |
| hufeisen rims | JustYYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 01-17-2007 04:16 PM |
