The Last Baron
Drives: 09 Polar White HB Join Date: Jun 2009
Fake alarm light
yeah so i dont have the $$$ to spend on an alarm. BUT i have all these components to build this ->http://www.discovercircuits.com/DJ-C...kecaralarm.htm can i apply this to the yaris (2009)? i am fairly competent with a soldering iron and know my way around wires and such. the only hard part would be locating the wires. but i need to know if this circuit wont freak out the yaris in ANY way at all.
thanks for your input.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires! | UR 19mm sway | |
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
Looks like that drawing is using a simple JFET or transistor to switch power to a flashing LED. Only problem is I've never come across a "flashing LED" as in a self-contained unit. Regular LED's are fairly common, so if I were to build this circuit I would use a regular LED driven by a 555 IC timer in astable mode to get the flash effect. Fairly easy circuit to build and the parts are certainly very common. Something like this:
http://wild-bohemian.com/electronics/flasher.html We have our students build these circuits all the time and they last forever. Note: Obviously it would not be a good idea to connect this circuit to your ignition wiring directly but to something that is powered via the ignition switch signal... like your radio. |
Here is one that is plug and play http://appsdiscounts.com/Site/Home-1.html $7.00 shipped
#4 | |
Nice find! kewl. |
Economist
Drives: 2007 Yaris Lifback Join Date: Oct 2009
I have a fake alarm light. I went through quite a few different LEDs, because most of the flashing LEDs you can find online or at the shop (or at least Radioshack) flash at far too quick a rate to be the slightest bit convincing. (And, of course, half the time the flash rate isn't advertised.) I recommend the Varad LL-RE; it has an adjustable flash rate, draws under 20 mA, and is much, much, much less frustrating than getting one that flashes 100 times a minute.
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
radio shack sells 12v blinking leds for 2 bucks
Drives: 2007 4 Door Yaris Join Date: Jan 2009
why? Is someone really gonna try to break into your car and be scared away by a blinking light? They don't get scared away half the time when real alarm start going off. I would think a viper license plate frame or sticker would be more effective.
If you're good with soldering/electrical, why don't you try to find a cheap used alarm somewhere and make it work? |
#8 | |
Half a Bubble Off Plumb
They're useless. |
Hardly. When insurance companies stop giving discounts for car alarms, then they could be considered useless. They don't cut into their profit margin for no reason. Alarms are supposed to be annoying, that's why they are called "alarms" and not "excuseme's"... Scorched Earth! |
The Last Baron
thanks for the input guys.
ruffstuff :i was previously looking at a timer circuit so ill keep that in mind. supmet: the point of this was that i have all the parts laying around in a box and to keep cost to an EXTREME minimum. i know the people who really REALLY want to get in will do so but what i dont want are the little assholes(we have mostly kids in the neighborhood that will not contribute positively to society) who walk around messing with shit trying to get in my car, so yes i do hope that a small blinking light will scare them however unrealistic that may seem. thanks for the suggestion about the viper sticker i should find a couple of those.
![]() Drives: 2009 5dr Join Date: Jul 2009
This is too weird....
I have a 2009 LB ( not sport) and I have a blinking dummy alarm LED by the outside edge of the driver's side defrost duct... Am I special or is mine really a self destruct indicator..? |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
You have an immobilizer. The engine can't start without your key.
#14 |
why not go ahead and build an alarm while you're at it?
#15 |
cosmo >> is this cheap enough? http://cgi.ebay.com/ebaymotors/ws/eB...m=380169604483
got mine >> that's the immobilizer led |
#16 |
The Last Baron
Tamago i think i will build an alarm and wire it to a "backseat monkey" that throws stuff at anyone who tries to enter.
seriously though the initial idea was that i literally had these resistors and transistors so my cost would be $ZERO. but that link sex posted looks very interesting. thanks sex i need to look into that one.
#17 |
#18 | |
![]() ![]() ![]() Drives: 08 Toyota Yaris Sedan Join Date: Jan 2009
haha i think thats what everyone needs!! funny vid!
- Arvin |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
| VIP Alarm V3 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 08-04-2009 01:43 AM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
