Old 12-26-2009, 11:11 AM   #1
detroiter
detroiter's Avatar
Which is more performance oriented...Tein stechs or TigerTecs?
Just wondering which of the two would offer the better performance as far as springs go? Also which ones sit the car lower?
The TigerTecs that I have already put the car pretty low (but not slammed) so I can't imagine springs that would make the car be any lower.
The reason I ask about the performance aspect is because the spring rates are as follows..
TigerTecs--Front:4k--Rear:3k
Tein S-Techs--Front:3k--Rear:3.5k
So the Tigertecs are stiffer up front and looser in the rear,
but the Teins are looser up front and stiffer in the rear...
What exactly would the difference be in those ratings? And I'm taking in account also that the Teins are supposebly lower than the TigerTecs, so that would also lower the cars center of gravity?
Old 12-26-2009, 11:38 AM   #2
kngrsll
Apexing Egg!!
kngrsll's Avatar
thats a good question. if you plan on the big rear sway bar, i think the tigertecs would be the way to go. if you dont plan on a rear bar, or get the smaller version, i would get the teins. it seems to really help this car by having a stiff rear end.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 12-26-2009, 11:41 AM   #3
Some people say the Teins are "bouncy", but I haven't ridden in a car with them installed. Also, yes, I think the Teins are a little more of a drop than the TigerTecs. A shorter spring (lower drop) will need a higher rate to "match" a taller spring with a lower rate.
My Silk Roads are 7k front 5k rear but feel fine on the street. I really don't think you can just compare rates and 100% have that translate into how the car feels while driving it.
Old 12-26-2009, 11:55 AM   #4
kngrsll
Apexing Egg!!
kngrsll's Avatar
one of the reasons i stayed away from the teins was the amount they lowered the car. the reduction in front strut travel made me nervous, front struts are very sensitive to ride height, and alot of time, going low can do more damage to handling that keeping it higher.
Old 12-26-2009, 04:41 PM   #5
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Actually , If you only change just the springs the Tigers will give you more understeer , the Teins will give you more oversteer . Understeer is safer . Oversteer , with lots of practice in a safe environment , can be fun and an advantage in a tight situation ...
The Tein with TRD shocks to me are pretty darn good . I'll admit , its not the absolute best set up for the track , they are not silky smooth , nor are they harsh . For mountain driving , they are perfect .
Old 12-29-2009, 02:00 AM   #6
Originally Posted by HTM Yaris View Post
Actually , I you only change just the springs the Tigers will give you more understeer , the Teins will give you more oversteer . Understeer is safer . Oversteer , with lots of practice in a safe environment , can be fun and an advantage in a tight situation ...
+1, I like my S.Techs and TRD shocks.
Old 12-26-2009, 10:49 PM   #7
detroiter
detroiter's Avatar
Thanks for the insight HTM. So why would the Teins give more oversteer and the Tigers would give understeer? I just want to make sure I understand things right. My current setup is Tokicos, TigerTec springs and a UR 23mm sway bar. I'm thinking whether or not of switching to Tein S-Techs or not, if there is even much difference between them and the TigerTecs to justify switching springs.
Old 12-27-2009, 11:40 AM   #8
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Alright. I tried before on Tanabe NF(2.5 frt & 2.2 rear) and Tein Stech (3 frt & 3.5 rear)springs. Those are about the same category of spring rate set-up as you posted, softer on the front to the rear and vice versa.
How much do you find your current set-up in your ride? Do you like them to be more over-steer(increase steering)? If not, it will be good for you to stay as it is.
I must say that the Tein S-tech are really stiff over my NF springs but they provide me SO MUCH more of steering which i love it but i really can't take the "super low" form and discomfort due to the high stiffness. In the end i sacrifice the "increased steering" for more "comfort" by putting back my NF springs. It is all about compromise.
Any car with higher spring rate on the front than the rear will provide u more "understeer" characteristic.
Where higher spring rate on the rear than the front will provide you more "oversteer" characteristic.
Hope the above will help you to make better decision.
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 12-27-2009, 09:53 AM   #9
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I had Tein S-Techs in my evo and didn't like them. They lowered the car too much, and were too bouncy.
Based on specs alone, I would probably go for the TigerTecs if you're leaning towards performance.
Old 12-27-2009, 12:12 PM   #10
detroiter
detroiter's Avatar
Well I'd prefer to have an oversteer tendency than understeer. I'm curious since I'm running Tokico shocks, would I run into rubbing from the tires and bottoming out if I went with the Tein's? I havn't had any issues from bottoming out or rubbing with the TigerTecs even when I have people in the car. But since the rear springs on the Teins are even stiffer than the Tigers, I'd imagine it wouldn't be an issue.
Old 12-27-2009, 12:44 PM   #11
evo165
evo165's Avatar
The only thing i'm afriad is that how much lower is the Stech gonna give as compare to Tiger springs.
You'll love the "increase" steering by having a higher spring rate on the rear than the front.
The best and safest bet, get those lightly used set of S-tech springs. If they do rub on the rear with passagers for being too low, you can easily change back to your tiger without burning big hole on your pocket.
Old 12-27-2009, 12:50 PM   #12
Brentorius
Drives: 07 Mazda MX5 Copper Red
I am installing tein springs with the tokico blues on Wed. I'll let you know how I make out.
Brent
Former Yaris Owner
Brentorius is offline   Reply With Quote
Old 12-27-2009, 03:24 PM   #13
detroiter
detroiter's Avatar
Please do man! ^
Like I said, I don't think it would be a problem since the rear springs are stiffer than the Tigers, but since the Tein springs make it a bit lower in stance, I wonder if that would compensate and cause the possibility of rubbing or bottoming out.
The lightly used Teins are not a bad item but for $200, I can get a brand new set. I'd rather just spend the extra 25 bucks.
Old 12-27-2009, 03:52 PM   #14
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
You should be fine with the Tiger Techs . The addition of the UR sway bar should balance it out pretty good .
I've had 5 adults in my car . Never bottomed out . The car actually rides smoother with more people (weight) .
Old 12-28-2009, 03:23 PM   #15
detroiter
detroiter's Avatar
Which springs is it that you never bottomed out with HTM? Appreciate all your guys help.
Old 12-29-2009, 03:12 AM   #16
coffiend
coffiend's Avatar
Drives: 08 Black LB
<3 my green springs :D
Old 12-30-2009, 03:29 AM   #17
alch3miss
alch3miss's Avatar
Drives: Toyota Yaris
i love my tein coilovers
alch3miss is offline   Reply With Quote
Old 12-30-2009, 08:36 PM   #18
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Tein Stech . Sorry for the late reply . The operating room has been hopping lately . Everybody is trying to get their surgeries done before the end of the year . Lately we have been averaging 150 surgeries ...a day . 20-30 of those involve me . Tommorow ....163 cases are scheduled
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
>>>>>> Boxing Day Sale at TWM Performance; Short Shifters and Shift Knobs <<<<<< TWM Performance TWM Performance 0 12-24-2009 10:21 AM
Tein or Sprint Performance?? youngxlos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-17-2009 10:33 PM
07+ Yaris Tein Springs/Suspension CorSport CorSport 0 07-09-2009 01:18 PM
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 05:08 PM
