Old 11-22-2009, 06:51 PM   #1
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
MAINT REQD
Is it possible to change the MAINT REQD from 5000 mile intervals to 3000 mile intervals? Maybe via the Techstream tool?
andaconda is offline   Reply With Quote
Old 11-24-2009, 07:37 AM   #2
andaconda
andaconda's Avatar
nobody?
Old 11-24-2009, 09:44 AM   #3
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
The quick answer appears to be no, however, when resetting this reminder there are five dashes that appear and each one clicks off one at a time during the reset procedure-so I wonder if each dash represents one thousand miles? I never tried it, but you might try resetting your reminder and only delete two of the dashes and see if that works. If it works it will only be by goofy luck since the system was clearly not designed to be adjustable like on some cars.
UTVitz is offline   Reply With Quote
Old 11-24-2009, 02:37 PM   #4
supmet
Drives: 2007 4 Door Yaris
^^ if you don't let all the dashes disappear the light doesn't reset
Old 11-24-2009, 10:15 PM   #5
andaconda
andaconda's Avatar
Bummer
Old 11-24-2009, 02:41 PM   #6
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
NO, question answered....
Maint Req. ItsMyDaily DIY / Maintenance / Service 26 09-13-2012 04:02 PM
Maint Reqd light Darb DIY / Maintenance / Service 8 02-09-2010 10:39 PM
MAINT REQD light PSU Yaris DIY / Maintenance / Service 9 12-24-2008 05:48 PM
Maint Reqd FLASHING Trilixia DIY / Maintenance / Service 10 09-28-2007 11:47 AM
