![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
I'm stuck - front springs and shocks
I can't loosen the f*cking bolt at the top of the shock.
This is what happened to my allen key ![]() And this is how the bolt is looking like right now: ![]() Any ideas?
5% Tint Rear | Micro Image LED Ignition Light Kit |
Hire a impact gun , worked for me .
Did you try using a breaker bar on your wrench? Looks like you need lots more leverage.
...or just get the right damn tools... Went to Autozone and picked up a set of box wrenches with a deeper offset. Worked like a charm on the 2nd try... Now I feel like an idiot
やりすぎだ~
Good thing you got the right tools. Luckily that nut still had meat to grab on
or you would've been in an even bigger mess. Good job! You're installing drop springs I assume? |
#6 | |
keep it up your almost done |
Thats what happens when you use cheap tools. Get a good allen wrench key and use a pipe on the end. Thats what i did and had no problems.
Well, I didn't want to be an ARROGANT idiot
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
Glad things are going well fmicle. Remember I want to see those wheels...
In pictures or in person? Either way is fine with my by the way
www.yarisclub.gr
Drives: yaris 1.3 2sz - 1.33 1nr Join Date: Jan 2009
coca cola
had a similar thing happen w/ mine
had to use an air impact wrench and a half can of liquid wrench to get the top apart other option: compress the spring to relieve the pressure on the plate, then hold the plate and use an impact wrench.....had to do something similar to that too.... edit: but now i see you got it apart...
| New OEM KYB '07 Liftback Springs & Shocks (Struts) | GuySmily | Items for Sale by private party | 7 | 07-25-2010 06:02 PM |
| Tanabe NF210 + Tokico vs. TRD springs and shocks | fmicle | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 11-19-2009 04:42 PM |
| What Shocks for Eibach springs? | ibizagti | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 03-26-2009 06:38 PM |
| TRD Springs Shocks and Sway Bars IN STOCK | Sparks Toyota-TRD | Sparks Toyota | 0 | 03-12-2009 10:54 AM |
| Newbie needs help with springs and shocks | xray scatter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-21-2008 01:39 PM |
