Old 03-17-2009, 03:36 PM   #1
YAR1S
YAR1S's Avatar
bulbs behind headlight reflectors?
Are there small bulbs behind the side reflector on the front headlights?
not the ones on the actual body of the car... but inside the headlight.
One side seems to be illuminated and the other not.....
how to fix?
-Jen <3
Old 03-17-2009, 04:47 PM   #2
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Yes there are. The only way to get at them is to remove the headlights ...
devinlamothe is offline   Reply With Quote
Old 03-17-2009, 09:18 PM   #3
YAR1S
YAR1S's Avatar
gosh..... that sucks..... do you have to remove the back part of the light too? ;[
-Jen <3
Old 03-17-2009, 09:41 PM   #4
You have to remove the front bumper to remove the headlights. It is actually quite easy - I removed mine to put in my Silverstar bulbs. Look at the lighting section of the service manual, which is posted in the DIY area. It walks you through removing the bumper and light assembly.
Oh, and no you don't have to remove the back of the light, you just twist the bulb socket and pull it out.
Old 12-05-2009, 02:27 PM   #5
YAR1S
YAR1S's Avatar
what the bulb number or can I find that in the manual? :p
-Jen <3
Old 12-05-2009, 04:24 PM   #6
This thread has the list of all of the bulbs for the Yaris:
http://www.yarisworld.com/forums/sho...ght=bulb+guide
Old 12-05-2009, 05:31 PM   #7
YAR1S
YAR1S's Avatar
Thats exactly why I this thread, thanks cscott!
-Jen <3
Old 12-05-2009, 02:43 PM   #8
90tsi
90tsi's Avatar
Drives: 09 yaris
not if ya got a skinny hand.. its cake
90tsi is offline   Reply With Quote
Old 12-05-2009, 03:41 PM   #9
RedRide
RedRide's Avatar
You don't have to remove the bumper to remove a headlight.
Just remove the bumper retaining pins near the headlight and bend the bumper a bit to expose the one healight bolt that is under the bumper.
It's relatively easy.
how to change headlight bulbs? PETERPOOP DIY / Maintenance / Service 57 05-01-2016 05:06 PM
Replacing headlight bulbs nsmitchell DIY / Maintenance / Service 47 02-14-2016 09:07 PM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
Yellow, Purple, Green Headlight BULBS? jamal1984 Cosmetic Modifications (Exterior/Interior) 12 02-04-2007 08:30 AM
