Old 12-17-2009, 12:57 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
changed belt,got scan code POO1O
changed the serp. belt and got ROUGH run and scan code P0010
What the h is this...????
cleared scan P0010 and got P0011...this is staying...
yaris9876 is offline   Reply With Quote
Old 12-17-2009, 01:46 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
didnt by chance hit your VVTI solenoid did you?
Old 12-17-2009, 03:15 PM   #3
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
P0010: Cmshaft Position "A"
Actuator circuit (BANK 1)
P0011: Camshaft Position "A"
Timing over-Advanced or System Performance(BANK 1)
Old 12-17-2009, 03:42 PM   #4
yaris9876
so what should I do? nothing is loose...or knocked off... can I play with the timing somehow like I used to do with the old distributors?? twist them around until it smooths out..??
Old 12-17-2009, 03:43 PM   #5
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
ya check solenoid
chongopants is offline   Reply With Quote
Old 12-17-2009, 03:50 PM   #6
yaris9876
where is it?? pic..??
Old 12-17-2009, 05:38 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
Yeah you damaged the solinoid possibly when prying against something. Another memeber had the same issue doing something similar. I think he was changing a pulley or something.
Old 12-17-2009, 05:40 PM   #8
yaris9876
I see a solenoid next to the stud that you use to pry the alternator bracket tight..it doesnt seem damaged at all
...after I changed the belt I did start it up without the harness plugged in there.. when I saw this I quickly
plugged it in. It is tight and secure.... These computer controlled cars are suppose to adjust the timing automatically to some degree.. It seems to be a bit better than the initial roughness..but still not really
smooth... the exhaust is not smooth. It runs ok... its not bad enough to not run and when under power its smooth enough.
That solenoid doesnt seem to move at all... does it pull out..??? the scan gauge would say if it was a bad solenoid anyway.... the code is for advanced timing.....
by the way ... can you or cant you buy an obd port machine that CAN make adjustments to some degree on these Toyotas..?? mechanics..??
If not, how can someone adjust the timing manually..??? there must be a way..
Old 12-17-2009, 08:35 PM   #9
The timing is completely controlled by the ECM. Try disconnecting the battery for a few minutes to clear the short term data from the ECM.
Old 12-17-2009, 07:59 PM   #10
bronsin
bronsin's Avatar
Sounds to me like you did in fact dammage the solenoid. At least that is the likely possibility. My first step would be to change it. Or at least look at it again. What else would throw that code?
Old 12-17-2009, 10:31 PM   #11
yaris9876
that is a good comment..I knew there would be one eventually..
I actually thought of the battery a few minutes before I read this....
I bet it fixes it.
by the way... this thing where you disconnect both terminals and touch positive to some metal to ground it...
is this safe?? as long as both cables are off the battery....this unloads the capacitors and totally clears the learned memory thing..??
mechanics....
ACTRON Pocket Scan Plus OBD2 Code Reader hatchbackkid82 Items for Sale by private party 0 12-16-2009 11:17 AM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 06:56 PM
