Old 12-17-2009, 05:23 PM   #1
zully
zully's Avatar
Drives: Yaris 1.3 sr
Front Wiper Problem need help......
Hi all,
Ok I recently purchased my 2000 yaris 1.3 sr, problem im having is when it rains the wipers most of the time come on automaticaly and don't turn of, even when the windscreen becomes dry, when i switch the car of and leave it of for a couple of hours it some times stops, but majority of the time im having to remove the fuse 'cause it's really annoying driving around with the wipers on.
problem only happens when it rains, is there some type of sensor that i can disable?
Help on this would be much appreciated.
zully is offline   Reply With Quote
Old 12-17-2009, 09:51 PM   #2
I don't believe that any generation of Yaris ever had automatic wipers. The wiper relay is built into the wiper switch, so I would suspect the switch assembly. If you pop the connector off when the problem is occurring you'll know for sure.
Old 12-18-2009, 02:57 PM   #3
zully
zully's Avatar
Hey thanks for the reply, problem only happens when it rains, wipers just come on automaticly. is there a guide on how to remove the wiper switch and relay, ill try replacing these and see if this sorts my problem out.
Old 12-18-2009, 03:19 PM   #4
Did they always come on automatically, or did that just start recently, when they would then also not shut off?
Here's a DIY on removing the wiper stalk (the relay is inside of the stalk and isn't separately replaceable). This is for a newer generation Yaris, but I would expect it to be very similar on yours.
http://www.yarisworld.com/forums/sho...ht=wiper+stalk
Old 12-18-2009, 04:06 PM   #5
zully
zully's Avatar
Ive only had the car for 2 weeks, and noticed it only comes on when it rains, it some times goings of by it self, but stays on most of the time....... thanks for the link to the manual. will try opening it on the weekend....
Old 12-18-2009, 04:08 PM   #6
Hmmm. It is also possible that the prior owner wired them up to run automatically, using parts from a vehicle that is so equipped.
Old 12-18-2009, 04:10 PM   #7
zully
zully's Avatar
Could be, is there anyway i can find out.......
Old 12-18-2009, 04:18 PM   #8
If that is the case, the modifications to the wiring should be quite visible either at the connector to the switch or at the connection to the wiper motor.
Old 12-18-2009, 04:20 PM   #9
zully
zully's Avatar
Will have a look at it over the weekend....
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 12:52 PM
24mm FRONT swaybars in stock cali yaris Micro Image 22 04-24-2009 04:47 PM
Displaying Front Plate In CA hans_fh California 42 10-22-2008 01:57 AM
