Old 01-13-2010, 10:52 AM   #1
Cutie Pie #2
Drives: 2014 Honda CR-V LX
Question about temp.
It has been very cold here and probably everywhere else, well my concern is I have noticed that the scan gauge temp. has been going up and down every time I let off the gas by about 20-30 degrees, also when it does that the temp. coming from heater goes up and down also. I also have notice in the morning when first start the car there is a noise for a second or two (sounds like a car without a muffler) that has only happen 2 times. Could the water pump be going bad or is this just a regular thing with the Yaris. All is fine after that except for what was mention above. I'm taking car in to dealer to get oil change and will ask them to check it out. Just wanted to know if anyone else has had this happen?
Cutie Pie #2 is offline   Reply With Quote
Old 01-13-2010, 11:16 AM   #2
127.0.0.1
yes have the dealer check it, this is not normal
the Yaris should behave like any other car. what you report is odd. sounds like low coolant
Old 01-13-2010, 11:21 AM   #3
Cutie Pie #2
[QUOTE=127.0.0.1;432400]yes have the dealer check it, this is not normal
the Yaris should behave like any other car. what you report is odd. sounds like low coolant[/QUOTE
The coolant level is a little below the max line.
Old 01-13-2010, 12:38 PM   #4
b_hickman11
Drives: 08 Sedan
Maybe something is wrong with your Scan Gauge.
Old 01-13-2010, 01:23 PM   #5
127.0.0.1
"also when it does that the temp. coming from heater goes up and down also"
if it were a scangauge error, the above can be explained by warm vs cold air mass in the
vehicle moving around during decel....but my piglet doesn't do it
Old 01-13-2010, 01:30 PM   #6
Cutie Pie #2
I could see that, but the inside temp.for the heat goes up and down also, to the point that it has a cold feel to it, and the coolant level is just below the max line, well anyway I'm going to get it look at on Friday, I will keep you posted on what happens.
Old 01-13-2010, 01:42 PM   #7
127.0.0.1
plus an odd sound in engine....possible big air bubble in water lines
Old 01-13-2010, 03:29 PM   #8
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Take the radiator cap off with the engine cold. If it's not full to the cap with the engine cold, it doesn't matter what's in the coolant tank. The air bubble will allow for expansion of the coolant as it heats, it won't push any excess out into the recovery tank, and it won't make a sufficient vacuum to pull coolant out of the tank into the radiator. The system needs to start out with the radiator, water jacket and lines very nearly purged of all air to function properly.
Old 01-14-2010, 10:30 AM   #9
Cutie Pie #2
I took radiator cap off and it was full there, well I'm taking it in tomorrow to get it checked out. I have change jobs and are alot closer to home, I only drive about 10 mins to work, so this maybe the reason why the temperature is doing what it's doing I just thought of that.
Old 01-14-2010, 10:50 AM   #10
127.0.0.1
nope.
it should behave. it should get warm and stay warm. jumping around is not normal.
a car temp will -feel- different on corners as cold/warm air masses inside the cabin get thrown around,
but the electronics reporting a difference ? that is some internal problem
Old 01-14-2010, 10:52 AM   #11
Yaris Hilton
Smile
Just another thought: When you're feeling waves of cool air with the heat running, are you going around a curve or corner? Even at moderate cornering forces, the distribution of layered warm and cool air in the cabin shifts markedly.
Old 01-14-2010, 11:04 AM   #12
Cutie Pie #2
Yeah that might be it too, but the temperature on my scan gauge will go up to about 186 where it should be but then when I either let of the gas or brake I see the temperature go slowly back to 168 and sometimes even down to 140 and then when I give it gas it goes back up to 190 then it is fine,but today I noticed it went down to 168 when I put it park and felt the temp. inside the car go down a little. And this was when the car was warmed up. The car had never done anything like this before, but I did have a longer commute before.
Old 01-14-2010, 05:57 PM   #13
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
wonder if your thermostat is phuxord... or a sensor is loose/malfunctioning
temp changes should only be like +/- 2F from cruise to brake... most of the time I don't see a change, unless it is early on in the commute.
Old 01-14-2010, 07:26 PM   #14
b_hickman11
Drives: 08 Sedan
Is this when the engine is cold or hot?
Old 01-14-2010, 07:40 PM   #15
Cutie Pie #2
After 10 minute drive to work.
Old 01-15-2010, 04:50 PM   #16
Cutie Pie #2
Well got back from dealer, after all it was just low in coolant and they said with the colder temperature outside these cars act that way sometimes. I went ahead a got them to pressure check(no leaks found) the system and replace coolant with new anyway, they said all is good. So I feel better now.
Old 01-15-2010, 05:53 PM   #17
TheSilkySmooth
TheSilkySmooth's Avatar
Hope service was free! Replace coolant? It s long Life coolant?! You just said coolant level was OK. I think the lied as usual.
Old 01-15-2010, 06:31 PM   #18
Cutie Pie #2
It was free, well I prepaid (oil changes, coolant change, tire rotation, wipers) for 3 years when I purchased the car. They put what ever coolant that is required for the car. It was low when I checked before going, but I requested them to change it plus it was free.
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 01:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 04:57 AM
Question about the Engine Overheating LED captainm27 DIY / Maintenance / Service 1 07-21-2009 10:09 PM
Inlet air temp vs. vehicle speed LtNoogie Performance Modifications 8 04-27-2009 01:20 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
