![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2006
Gas pedal problem?
Got my Yaris Hatchback 5 speed a few weeks back. The problem I am having is that at the top of the gas pedal there is about 1/2" of play. This makes coordination of starting out/shifting quite difficult. I didn't have this problem on the HB that I test drove. When I first got the car I was stalling it out @ 5 times a day but now just @ once every other day. I am finding that I've started to rev a bit before starting out. I'm not new to 5 speeds as I drove my Geo Metro for 11 years and 211,000 miles before it got totalled out on 5/22/06. I haven't taken it to the dealer as yet as they are @ 60 miles away. Has anyone else experienced this? Have a fix?
Also the engine doesn't seem to 'rev down' very quickly when shifting. Makes for some pretty sloppy shifts. |
![]() ![]() ![]() ![]() Drives: 06 yaris 5-dr le man Join Date: Mar 2006
yeah, ive been driving stick for almost 20 years and this car was a big adjustment for me,
the yaris has a drive-by-wire system with electronic throttle, so it has a different feel to it, it also holds on to the rev a bit longer when you let off of the gas. it took me a few months to get used to it |
i dont' have a clue about whether it is adjustable or not, but mine drives the same as the two i test drove, so i assume it is not faulty,
i'm used to it now, so i think i just let of the gas a bit quicker when shifting gears. |
#4 | |
![]() ![]() ![]() Drives: WRX ,Tacoma and Yaris Join Date: Apr 2006
I brought this throddle response up a few weeks ago and people thought I was nuts. I have been driving sticks all my life . The throddle response is slow. After driving my Yaris for a couple weeks, I got back in my WRX for a drive and almost got whiplash. I am use to it now and no problem.
TRD_YARIS I'm sure will have good info to add on this subject..
#7 | |
Are scions all drive by wire?
I commented on a post dealing with fuel. I too had the exact same problem in my Yaris but I thought that maybe it was the 98 octane fuel I was using for about 3 months. I then changed to 95 octane and the problem began to go away. My Yaris is running 100% now and thought that this might help you all. If you are running 95 try 91 or maybe even go higher.
![]() Drives: Yaris YRS 1.5 Hatch Join Date: Jun 2006
I've got the same problem, except mines an auto.
I put it down to the fact that I'm still breaking in the engine. |
what problem do you have with the auto? the play in the gas pedal?
If I depress it approx 3 cm nothing happens.
It's very annoying... |
that sounds wierd, mine doesn't have play like that
I will be heading out to the dealer this morning and will let you know what I find out.
#15 | |
#16 | |
![]() Drives: 2010 Yaris Join Date: Jan 2010
Notice the same thing here with the 2010. Have a 91 Celica and 95 Tacoma and it sure was a crazy difference with the response of the throttle. Could be related to the runaway problem I posted about on the other thread here. It is actually worse in the extreme cold like we had a couple weeks ago. I have nearly 2-million miles on stick and this is the first one I seem to stall every time. Other half also has hundreds of thousands of stick time and this is the first vehicle that stalling is common on due to throttle response.
Throttle response is completely dependent on ECU programming. Same goes for Auto tranny shift points. I've done reprogramming of Sienna's (a while ago now) ECUs because of shift problems. Transmission would shift too fast from R to D and cause a clunck.
The new Prius is a perfect example of ECU controlled throttle response. You have Normal mode, Pwr mode, Eco mode and EV mode. In Pwr mode the car has lots of power with very little input, as where Eco mode the power only come on in say, the last half of the peddle travel. |
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
| poll concerning gas prices | foober | General Yaris / Vitz Discussion | 15 | 07-24-2006 12:47 AM |
| Yaris 2001 - serious problem | adnanmalik | General Yaris / Vitz Discussion | 10 | 06-19-2006 08:59 AM |
| Full Gas Tank Noise? | hoahmaru | General Yaris / Vitz Discussion | 8 | 04-10-2006 12:17 AM |
