Old 02-06-2010, 11:33 AM   #1
bitz767
Drives: 2010 Black Manual 3 door
Bigfoot modification and Weathertech floor mats
has anybody done the bigfoot modification of removing some of the foam next to the clutch pedal and then tried to put in weathertech floorliner digital fit mats?
http://www.weathertech.com/store/mvp...ptChoiceIds=59
I really want these mats but I have to do this mod so I can actually press the clutch all the way in. Any thoughts?
bitz767 is offline   Reply With Quote
Old 02-06-2010, 03:24 PM   #2
yaris prime
Yes- I fit in it.
yaris prime's Avatar
Drives: 2007 Yaris liftback, MT
I have done the bigfoot mod and highly recommend it, as it made a world of difference. I can't speak for the floor mats, but I would assume that they are a pretty stiff molded material which may give you issues as I am sure it is made to go over that area.
I'm surprised it doesn't have a pull-start !
yaris prime is offline   Reply With Quote
Old 02-06-2010, 03:58 PM   #3
DARK AGE 53
Drives: 2009 Yaris Onyx
I guess I really don't get this Bigfoot mod, how does this mod help in depressing the clutch pedal? I have the Weathetech floorliners and from what I can see the Bigfoot mod and Weathertech liner won't work together.
DARK AGE 53 is offline   Reply With Quote
Old 02-06-2010, 05:15 PM   #4
bitz767
the bigfoot modification removes some of the foam from the left of the pedal. My size 14 boots dont do so well putting the pedal to the floor and sometimes i am grinding the gears when i am shifting. I really want those mats. I wonder if I could just cut the top corner off of them and then jimmy rig something up to fill in the part where I cut it.
Old 02-10-2010, 12:28 AM   #5
127.0.0.1
just use a razor and cut and origami the weathertech to fit the mod
and use a blob of shoe-goo to seal it back up. you can make digital fit
mats work on the bigfoot mod with a razor and some time
Old 02-10-2010, 10:31 AM   #6
bitz767
sweet, just what i wanted to hear. Ill order my mats now. Thanks
