![]() Drives: Vitz Join Date: Nov 2006
Need help with airbag light on....
my car's keyless entry didn't work, airbag light (both) on, passager's seatbelt light on (no one sitting there), immibilizer didn't work, whenever i start the car, the time always reset to 1:00, the lock/unlock button doesn't work without i start my car.....
anyone know how to solve and what happened? need help please....ASAP......
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
If the passenger airbag light is on as well as the seatbelt light, you need your airbag system re-calibrated. This happened to me after a rear-end collision. This was covered for me by insurance so I have no idea how much it will cost.
This post explains how to get the SRS ECU to flash its light to tell you what the stored codes are:
http://www.yarisworld.com/forums/sho...0&postcount=78 This one explains how to reset the stored codes: http://www.yarisworld.com/forums/sho...&postcount=205 Some of the stored codes require individual resetting, so if you have 3 stored codes, you may have to do the reset procedure 3 times. |
find out what happened....the ECU-B fuse burned.....
but right now my fog light doesn't work.....it works when i didn't start the engine, but when i start my engine, the fog light it's gone....when i turned it off, the fog light on again...
Check the ECU-IG fuse.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Help! Airbag light issue | Astroman | DIY / Maintenance / Service | 24 | 05-18-2019 12:35 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Anyone get the Check airbag light to go away when you installed racing seats or wheel | wholenizz | Cosmetic Modifications (Exterior/Interior) | 1 | 06-17-2009 08:14 PM |
| Airbag light is on | Taiyaki | DIY / Maintenance / Service | 4 | 05-26-2009 08:47 PM |
