The Martian
Washer fluid warning light "Backwards"
Okay so for the months since I got my car back from the body shop I have thought that they had wired the low washer fluid sensor wrong and that's why it was always on. Today I realize that when I'm low on fluid it goes off and when i fill it up it comes back on? So basically I have a Substantial amount of fluid warning light now-eye roll- I was wondering if the wires are just backwards so I wouldnt pull the bumper off for nothing?
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker. |
It's just a simple float switch that brings the line to ground when the level is low. I would bet that they installed the switch in upside down. It's not keyed to only be installed in one direction and it just has a tiny "V Down V" molded into one side of the lip.
The Martian
That just makes me laugh...I guess ill check it out when I get the time, they also put the wrong pump on the rear fluid hose and busted the hose inside the headliner>.<
| Tags |
| washer fluid light |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| SRS warning light - any guesses? | Goose | DIY / Maintenance / Service | 15 | 03-24-2014 02:57 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| Washer fluid "2.3 Full" | stran | General Yaris / Vitz Discussion | 1 | 11-02-2009 10:19 PM |
| Low washer fluid light | auxmike | DIY / Maintenance / Service | 3 | 12-14-2008 02:47 AM |
