Old 02-15-2010, 06:07 AM   #1
yarismo
yarismo's Avatar
Drives: Yaris HB luna
change rims from 15" to 17" on yaris HB
hey everybody, I want to change my original tires and rims to larger and bigger ones (15" to 17"), so I am asking if it will fits my yaris HB and whether any changes must be done on the car or not ? also, do 17" wheels limit the suspension to reach its max ?
wainting for your answers..thnx
yarismo is offline   Reply With Quote
Old 02-15-2010, 08:11 AM   #2
33OH
Drives: '08 Yaris
You'll be fine as long as you get the correct tire size/rim offset. It will raise your car so you may want to look into lowering it, but not a requirement.
Wheel & Tire Size Guide - http://www.yarisworld.com/forums/showthread.php?t=5021
Old 02-15-2010, 10:23 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Actually, with proper tyre sizing, the car will not ride (significantly) higher/lower than with the stock 15's.
OEM tyre size for 17's is 205/45/17. For best fitment, find a wheel with +42mm or higher offset.
Old 02-15-2010, 11:05 AM   #4
33OH
Drives: '08 Yaris
You're right Kimona, I suppose I should have said "may appear" higher. But it's definitely not necessary to lower your car, so try out some 17's and then decide!
Old 02-15-2010, 04:43 PM   #5
yarismo
yarismo's Avatar
thank you..
I didn't want to get something looks like this:
Old 02-15-2010, 06:31 PM   #6
DARK AGE 53
Drives: 2009 Yaris Onyx
17's on my Onyx.
DARK AGE 53 is offline   Reply With Quote
Old 02-15-2010, 10:57 PM   #7
Kal-El
Kal-El's Avatar
To the OP, there is a ton of info and 100's of pics in the "pics of yaris w/ aftermarket wheels" thread and the "wheel and tire guide" thread.
Old 02-16-2010, 12:01 AM   #8
smartazawhipz
5-Speed love
Drives: red 08 liftback
i've got 17s with no drop (yet), and no rubbing. 17x205x45 Yokohama S-Drives. Love'em!!
smartazawhipz is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
17" 5Zigen wheels with BFGoodrich KDW2 mounted on the yaris... vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 09-19-2007 01:39 AM
