![]() Drives: 2010 Yaris S Join Date: May 2009
2007 AT Yaris Disappoints me
Okay...
So I bought a used 2007 Yaris, AT, superbasic (no power anything). My wife and I share it, and though we're both conservative drivers - her a bit more than me - we're getting only 28-32mpg, typically getting 30 mpg on a tank. Now at first, I was okay with this because that's exactly what the EPA rating was, and for essentially an economy car it worked pretty well for our needs. However, after seeing these forums...I know there's a difference with the MT, and some hypermilers out there, but I've even seen some much higher claims for the AT. Which leads me to believe that either I've got a lemon, or there are lots of people out there who are calculating their mpg wrong ![]() The one thing that concerns me is where the AT shifts. I haven't paid attention to it in awhile because I like my loud music in the car, but it seems to shift into fourth around 45mph, so when on the freeway going 55-65, the engine sounds like it's running at an unhealthy rpm. Is that normal? It seriously sounds like it needs an OD to me...but honestly I know nothing about gas cars. Electric is my thing. Please help! I'd love to solve this before my roadtrip in April. |
You're getting pretty much the norm for an AT, cold weather, winter formula gas. The claims of higher mpg are basically exceptions, and not the norm.
At 55-65 mph, your engine will be spinning at around 2800 - 3000 rpm. This again is normal for small displacement engines. You have nothing here to worry about/fix before your roadtrip.
![]() ![]() ![]() Drives: . Join Date: Dec 2008
I'm pretty sure that my AT sedan is at 3K or so RPM when cruising at 80MPH.
#4 | |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
Even more impressive, when called upon, the Yaris' little 1.5L produces over half the power that the old 500 (8.2L) could. That's over 3x the power per litre displacement... and without any sort of turbocharging. -Steve |
#5 | |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Well as I said, I've had the car for awhile now and in no weather have I had more than 31mpg.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
I've tracked my gas mileage in my 08 Yaris LB (with an auto) since getting it in November 2008, and it always decreases during the winter. Driving easy, I only get ~33 MPG during the winter, whereas I am closer to 37-38 MPG during the summer.
Secondly, are you sure you're not knocking the shift lever out of OD and into 3rd gear? It happens if you're not careful. I drive at 60 MPH on most of my commute and the car doesn't sound like it is stressing; but we are only talking a 1.5L 4-cylinder engine and a subcompact that isn't as sound-proofed as a bigger, luxury car. I usually crank up the radio as well, so I don't notice it either; but I have checked just to see how the engine is running at highway speeds (not having a tach stinks) and it appears fine to me. Also, what kind of tires/rims are you running? I have aftermarket 17" rims and wider tires, which takes a bite out of my mileage. Friends with stock Yarii get better mileage... Cheers! M2 |
#9 | |
Nark!
So (drumroll)...what I found out was that I was NOT knocking the shifter into 3rd gear. I was CONSTANTLY DRIVING IN 3RD GEAR! Yes I am a fool. Yes you can laugh at me. But in my defense, I have never, ever driven an AT with a 3rd gear. Only L, 2, D, N, R, P. So for some reason, what I know see to be clearly labeled never even occurred to me. I just followed the notching on the shifter and wound up in 3rd. All the time. (My wife too). So I was right that it was at too high an rpm...and yet I was so, so wrong. So, knowing this, should I get my tranny checked or something? I feel like I've been damaging my poor Yaris for so long without knowing it. And to set the record straight, I love the Yaris. When I said I was dissapointed, it was because I saw case after case after case of people getting well over EPA, many claiming with an auto and without hypermiling (or without any hypermiling beyond the conservative driving I already employ). |
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
Nah, wouldn't hurt anything. Enjoy your improved gas mileage!
![]() ![]() Drives: 2009 yaris sedan base Join Date: Sep 2009
Yep winter gas in the north east and dedicated snow tires.. mileage fell on it's face.... was doing well over 40 mpg matter of fact 44.6 average sedan a/t with regular tires and non winter gas.. now down to low to mid 30's... either way better then 12 in my truck i figure
Winter gas is not limited to the northeast, we've got it down here in southcentral Texas...
![]() ![]() ![]() Drives: '07 Yaris Sedan/'03 Protege Join Date: Oct 2008
To the OP, where are you doing most of your driving?
And for the record, a lot of people don't know how to calculate their MPG correctly. Even on this forum. E-Present company excluded I am sure. |
#14 |
Most of the driving is freeway, I'd say 70/30. Actually I have never heard of "winter gas..." there's literally a different gas pumped in winter?! I'm using all-season tires, stock size. I'm pretty sure I'm not knocking the shifter out of D, as I don't even get close to touching it. To my ear it still sounds like it's stressing, but like I said, not too experienced with cars/mechanical stuff.
#15 |
Next chance I get, I'll take some video at high speed so maybe someone can give me an answer based on their experience.
#16 |
![]() ![]() Drives: 2008 Yaris Hatchback Join Date: Jan 2010
you have 2 different drivers driving the car it will be hard to get a good mpg due to differnt driving habits..I get 38 mpg in my car when my wife drives it she gets 34 mpg..Winter gas is less quality than summer gas and you'll get about 2-3 mpg less than summer gas. In Alabama we have the crappy winter gas
#17 | |
#18 | |
| Tags |
| automatic, fuel efficiency, mpg |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
