Old 07-25-2009, 04:04 AM   #1
jorizk
Drives: Yaris 2006 1.5 L Sedan
Question Yaris sedan low and high beam
Hello fellow yaris owners:) How are you doin' ?
Yaris's my first car I have been owning it for 3 years, I have the 2006 1.5 L sedan model, and I say honestly that's it's quite awesome!
Now let's talk about the beams. I noticed some while ago that when I engage the high beam the low beam turns off. Now There are cars that leave the low beam on when the high beam's on. And if you pull the high beam nob towards you (for flashing with the high beam), there's a brief moment when both lights are on. So I wanna ask is there a way to make them both work when the high beam's engaged (high beam nob pushed forward), and why do they do it like this? Is there a temperature problem if they are both on(since they both light up from the same bulb) or is it an electrical problem (they draw too much power if both on)..
Thanks a lot mates !
jorizk is offline   Reply With Quote
Old 07-25-2009, 04:13 AM   #2
Welcome, I'm not too knowledgeable on electronics, but it may be due to the fact that the highbeam and lowbeams are on the same bulb. Either that, or your guesses. hehe.
Old 07-25-2009, 07:27 AM   #3
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
The reason its not done is heat buildup and power demands on the electrical system.. but if you want to do the mod it goes something like this = http://www.stylintrucks.com/Articles...l/Article.aspx
Old 07-25-2009, 01:41 PM   #4
jorizk
Well yeah I guess this is the reason.. but it sucks:P
Let me explain how my light nob works. If the low beam's on, and you pull the light nob, then the high beam turns on and then the low beam turns off. So if you pull it a little you can hold it in a position where both lights are on.. (but it's not practical, i mean driving and holding the nob in the same time:P) Sure sucks.. the light when both beams are on is awesome:D
Old 07-25-2009, 04:24 PM   #5
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
It sound easy to me. Take the high beam wire from the knob and attach it to a new switch. Now you can add high beam anytime.
Old 07-25-2009, 06:58 PM   #6
PatrickJohnson
Drives: 2008 Yaris LB
to put it simply, you DON'T WANT them both on. It's like that for a reason, and most cars do this. It is for the reasons mentioned above, and it is dangerous to have them both on constantly, you can melt your housing.
PatrickJohnson is offline   Reply With Quote
Old 07-25-2009, 07:11 PM   #7
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
The bulb's envelope may overheat and pop, and the filaments will be operating above their normal temperature. You can anticipate short bulb life.
Old 07-26-2009, 10:22 AM   #8
jorizk
Oh okay :) Thanks a lot mates !!
Old 02-23-2010, 09:02 PM   #9
evoyuin
Drives: '06 Evo and '10 Yaris
bump
Hi everyone, I'm new to this forum, I would like to bump this subject if thats ok. I recently bought a 2010 yaris hb. I also have an mitsubishi evo, i wanted to know how much power is going thru for headlights?
evoyuin is offline   Reply With Quote
Old 03-01-2010, 09:06 AM   #10
Falconeer
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options
Total the wattage on the head lamps and add a bit (10%) for safety... or just check the fuse.
BOSCH 8000k HID Headlights, BOSCH 8000k HID Fog Lights. BOSCH Horn. 30% tint all round. 70% Tint mirror-finish tint on front wind shield. TRD Leather Shift Knob, Leather Steering Wheel, TRD Emblem. Height adjustable driver's seat is cool! and... That great armrest from ebay
Falconeer is offline   Reply With Quote
Old 03-02-2010, 10:49 AM   #11
evoyuin
thank you very much, this helps me with whether or not i should convert to HID's and if i need the relay wires.
High Beam Mod stran DIY / Maintenance / Service 1 11-13-2008 12:06 PM
Package received from Taiwan! GabL Cosmetic Modifications (Exterior/Interior) 74 09-25-2007 10:37 AM
