Old 03-01-2010, 01:15 AM   #1
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Equalizer Question
Which would be the "main in " From the Source Unit if you have the following outputs: Front, Rear , Center, and Sub
Old 03-01-2010, 06:04 AM   #2
CpKi1g3
High speeds are fun...
CpKi1g3's Avatar
Drives: 07' Polar White sedan Base
Send a message via MSN to CpKi1g3 Send a message via Yahoo to CpKi1g3
well brand would help my friend. what brand is it of the head unit? i have a sony Xploid head unit and it has a setting for it to set it as "SUB OUT" or "REAR OUT" and it has only one set of output RCA jacks. have you checked that?
CpKi1g3 is offline   Reply With Quote
Old 03-01-2010, 12:46 PM   #3
_S7V7N_
_S7V7N_'s Avatar
Mine is a JVC DVD player and it has all of the above, Front Rear, Center and Subwoofer outputs.
Model number is : KD-AVX2
Old 03-01-2010, 08:06 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Brand doesn't matter.. the "Main in" thing refers to the source... is the main an Ipod, a Sat Radio, or a deck... The eq sounds like it functions similar to a home theater receiver... pick what you want.
would be the front RCA's (from your deck)...
so you have a 5.1 deck?
do you plan on eq-ing just the fronts?
parametric or graphic, how many channels total do you have (on the eq)
Old 03-01-2010, 11:00 PM   #5
_S7V7N_
_S7V7N_'s Avatar
Clarion EQS746 1/2 DIN Graphic Equalizer with Built-in Crossover
Product Description
7-Band Graphic Equalizer 6-Channel / 7 Volt RCA Outputs (Front/Rear/Subwoofer) Adjustable Master Volume Level Control Adjustable Subwoofer Level Control 2-Channel RCA AUX Input with Adjustable Gain Selectable 12dB Low-Pass Crossover (60Hz or 90Hz) Gold Plated Terminals Dimensions:7"(W) × 1"(H) × 4"(D)
Another question is the 7 Volt RCA Outputs will effect my amp in what way ? I believe the Output from the Player is around 2.5V
And i'd like to use the eq to Run my Front, Rear and Sub.
<br>
<br>
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 01:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 04:57 AM
So question here abt hatchs in general Jem_hadar General Yaris / Vitz Discussion 12 01-06-2009 04:06 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
