Old 02-16-2010, 04:45 PM   #1
bankrobber
Drives: 2007 Yaris Hatchback
Coasting in neutral
Is coasting in neutral bad for manual transmission? I have been doing it alot. I usually pop it into neutral on my way home on a big hill where I can coast almost a mile where I have to stop and turn anyway. I was wondering if coasting would cause something to not get lubericated?
bankrobber is offline   Reply With Quote
Old 02-16-2010, 05:03 PM   #2
127.0.0.1
no it causes no harm
in a standard, no damage
in an automatic no damage
NOTE:
neutral will...
prevent DFCO from engaging and will wear out the brakes faster (no engine braking available)
but no damage whatsoever.
Old 02-16-2010, 06:45 PM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
If you coast in neutral with the clutch in, you're putting unneccessary wear on the throwout bearing. If you're going to coast in neutral, just be sure to let the clutch out.
Do look up DFCO, though. In FL, there really aren't many hills that are steep enough or long enough for you to benefit from neutral coasting. But, you can gain a lot from in-gear coasting with DFCO.
Old 02-16-2010, 08:52 PM   #4
bankrobber
Great, thanks for advice. I have always coasted a lot. I will keep the DFCO option in mind. I had no idea the Yaris did that.
Old 03-11-2010, 03:55 PM   #5
Boost Addicted
Drives: 2008 Yaris 5spd, 2005 GLI 1.8T
Most, if not all cars use this... In gear, with foot off the accelerator, the injector solenoids will be shut off to save on fuel. The wheels will keep the trans, and therefore the crank rotating. If you pop her in neutral, the engine needs fuel to keep the engine at idle speed.
Boost Addicted is offline   Reply With Quote
Old 02-16-2010, 09:15 PM   #6
YAR1S
YAR1S's Avatar
I thought using DFCO was more beneficial than coasting?
hmm.
-Jen <3
Old 02-16-2010, 10:07 PM   #7
BailOut
Steals terrorist's lunch
BailOut's Avatar
hmm.
It all depends on the scenario. If you only have a short distance to go, or want to drop speed over a shorter distance, then DFCO is the key. However, if there is a long way to go and/or you want to maintain as much momentum as possible then coasting is the key.
Hypermilers take it a step further and coast in neutral - with the engine off.
- Brian
Share the Road
Old 03-06-2010, 11:54 AM   #8
michaelmast
Drives: red
I never had any problem with my car specially when i come home i have to rive in a hill too, and usually i used in neutral just keep in mind that you have to be careful...
Cuban cigars | Habanos | Cigars
michaelmast is offline   Reply With Quote
Old 03-11-2010, 02:46 PM   #9
Josepe-sv
Drives: Yaris 2008 HB 1.5
What is DFCO?
Josepe-sv is offline   Reply With Quote
Old 03-11-2010, 02:52 PM   #10
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by Josepe-sv View Post
What is DFCO?
Deceleration Fuel Cut Off. At above 1100 rpm (IIRC) with the transmission in gear and the throttle at idle position, it will cut the fuel completely, saving you the 0.16 gallons per hour normally used at no-load idle.
-Steve
sbergman27 is offline   Reply With Quote
Fan setting to neutral (not hot or cold) defog? PhasedWalker Fuel Economy Forum 3 07-19-2009 01:21 PM
Deficit Neutral? yaris-me Off-topic / Other Cars / Everything else Discussions 0 07-08-2009 12:08 PM
So Close!!!! aclark246 Fuel Economy Forum 13 06-07-2009 10:02 AM
Shifting into neutral otterhere Fuel Economy Forum 24 01-17-2009 02:46 PM
Park, rear, neutral, drvie, 3,2,1 thingy BMGYaris Cosmetic Modifications (Exterior/Interior) 7 05-11-2007 11:06 AM
