![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
'09 5-door LB: Speaker sizes and brackets.
Anyone know what the speaker sizes are for the '09 5-door LB (front doors and back doors)?
I'd like to replace the stock speakers. I'd also need some mounting brackets for the replacement speakers. |
mate i put 16 cm pioneers in each and the 09 is the same as 08 =)
so you do not take take out the old speakers they are pop riveted in you just gut them i.e you pull out the speaker part unplug the old speaker part, plug it into the new speaker and just screw the new speaker into the old plastic speaker and use it as a mount ... you do this because the window will hit the speaker if it is just mounted in the door
Couldn't you drill the rivets out and use speaker brackets from Metra or Scosche?
i cant say i know what a Metra or Scosche is but it is easy as pie to just gut and re drill unless you want to keep the old speakers and yes you can drill the rivets if you want, you just need the spacer
Anyone know for sure if 6.5" speakers will fit in the front doors of the '09 5-door LB? What about the rear doors?
