Old 03-21-2010, 04:52 PM   #1
TwoBearWisconsin
TwoBearWisconsin's Avatar
Drives: 2010 Yaris LB/5, 1996 Miata
If you buy aftermarket alloy wheels...
Two questions - what does the stock 15" steelie weigh? and what happens if the alloy wheel doesn't accept the tpms?
TwoBearWisconsin is offline   Reply With Quote
Old 03-21-2010, 05:08 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Both questions have been answered multiple times before. I encourage you to give the search function a try.
Old 03-21-2010, 05:49 PM   #3
TwoBearWisconsin
Thanks for your help!
I have been searching and have not found the answers yet.
Old 03-21-2010, 06:22 PM   #4
tk-421
tk-421's Avatar
Drives: 5D-07-LB
OK based on what I could find, the the stock alloy rims with tires weigh 34 lbs.
As far as the TPMS issue, check out this thread and go from there.
HTH
Old 03-21-2010, 07:24 PM   #5
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
He was asking stock steelie weight though, I'm curious as well
Old 03-21-2010, 07:45 PM   #6
cmcguinness7
cmcguinness7's Avatar
Drives: 2007 Yaris sedan
+1
cmcguinness7 is offline   Reply With Quote
Old 03-21-2010, 07:54 PM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
wheelweights.net have them at 16 lbs each.
Colin Chapman disciple
Old 03-21-2010, 09:31 PM   #8
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by cmcguinness7 View Post
+1
That post states that the stock steelies weigh ~34lbs with tires.
Originally Posted by Jansen View Post
The stock alloy rims with tires weight 34 lbs, so my weight increase is 28%.
Unless that's referring to stock aluminum wheels, but it sounds too heavy for that...
Old 03-21-2010, 09:41 PM   #9
My stock steelies weighed 15.35 lbs alone and 16.25 lbs with the hubcap.
My stock Goodyear Eagle LS tires weighed 17.05 lbs.
As for the TPWS question, you can bypass the TPWS system to keep the light from driving you nuts:
http://www.yarisworld.com/forums/sho...&postcount=115
Old 03-22-2010, 12:52 PM   #10
TwoBearWisconsin
Thanks!
Sticker and Wheels (good buy?) YAR1S General Yaris / Vitz Discussion 3 05-03-2009 11:19 PM
