Old 01-25-2010, 05:43 AM   #1
goku87
goku87's Avatar
Drives: Black HB
How to get cruise control
I went to the dealership yesterday and was talking to a sales rep and one of the things I was looking for in a new Yaris would be cruise control. He told me I just need the power or sport package. However, my last Yaris had the power package, and it didn't have cruise control. So how do I for sure get it?
goku87 is offline   Reply With Quote
Old 01-25-2010, 06:10 AM   #2
Do it yourself. It will be far cheaper than paying for it from the dealer, and with an 09 or 10, all you need is the OEM stalk and cable.
Old 01-25-2010, 06:28 AM   #3
DevilGirl
Drives: 09 3dr LB MT
Just for shits and giggles, I asked my local dealer how much it would be to have cruise installed. Their response: "It's not worth it. There are numerous parts that need to be installed. Your cost would be like $1000-$2000."
Of course this was after I had read the threads about cruise control install, for which you just need the stalk, and if I remember right, the price was less than $20...
Old 01-25-2010, 12:58 PM   #4
goku87
goku87's Avatar
Drives: Black HB
My problem with that is in my '08 it didn't have the cruise control light in the cluster that I saw in the DIY, and I was under the impression that if it's not there, then it cannot be added. Am I mistaken?
Old 01-25-2010, 01:11 PM   #5
Starting in 09, they all have the two indicators on the cluster.
Old 01-25-2010, 01:14 PM   #6
b_hickman11
Drives: 08 Sedan
The power package Yaris comes with a different gauge cluster than what comes on the non-power Yaris. The power version has a light that says "cruise" when the cruise is activated. The non-power can come with a cruise but it will not be Toyota's parts. It will be the Rostra, which has the light built into the stalk. You can add the Rostra kit after buying the car.
Old 01-25-2010, 12:41 PM   #7
The problem is that if you don't get one with Cruise from the factory, they port or dealer install the $300 Rostra aftermarket CC, which requires a bit of (unnecessary) labor to install.
Old 01-25-2010, 01:05 PM   #8
eht13
Drives: .
Unless this has changed (since the Sport Package is a new thing), the Power Package is a necessity to also have cruise control, but having the Power Package does not automatically mean you will get cruise control. So if you want it that way from the dealer, you'll need to specify that cars you want to see have cruise control... in which case, they will also all have Power (and presumably, Sport) Package.
eht13 is offline   Reply With Quote
Old 01-25-2010, 01:16 PM   #9
b_hickman11
Drives: 08 Sedan
1. The Sports package is not new.
2. You do not have to have the power package to get cruise. My 07 does not have the power package but it already had cruise installed by the port.
Old 01-25-2010, 01:34 PM   #10
eht13
Drives: .
I was under the impression that the "Sport Package" was not available as a package per se until the 2010 model year... before that, there was the "S" version of the cars available, and there is no "S" anymore.
Regarding your second point, I was referring to the original, factory-installed cruise control... the difference that I think you pointed out here:
"The non-power can come with a cruise but it will not be Toyota's parts. It will be the Rostra, which has the light built into the stalk. You can add the Rostra kit after buying the car."
Old 01-25-2010, 08:33 PM   #11
b_hickman11
Drives: 08 Sedan
The "S" and the "RS" is the same thing, Toyota just changed the name to try to attract more buyers. "S" stands for sport and "RS" stands for Rally Sport.
If you already have the power package on a 2010 you can add OEM cruise or the Toyota's approved secondary version, the Rostra. If you dont have the power package and you have an 07 or 08, you would have to buy a whole new gauge cluster if you wanted true OEM. Although, Toyota has been installing the Rostra kit on it's non-power products for at least 10 years. My parents have a 2001 Toyota Tacoma with the same exact Rostra cruise that is in my 07 Yaris and the same that is in my co-workers 2010 Tundra.
So it all depends on how much $ you want to spend.
Old 01-25-2010, 08:54 PM   #12
For 2007 and 2008, factory cruise was only available on the Sedan.
For 2009, the "new car features" section of the service manual lists cruise control as now being an option for the liftback and shows the instrument cluster placing of the indicators. For 07 and 08 the cruise control sections of the service manual were specific to the sedan.
So, for 2009 and 2010 all liftbacks have the indicator on the cluster, regardless of which packages they have.
Old 01-25-2010, 09:19 PM   #13
goku87
goku87's Avatar
Drives: Black HB
Okay, so I just need the stalk and wires for the '10? Would I run into any problems if I got one for < '08?
Old 01-25-2010, 09:22 PM   #14
Same stalk and wire will work for any year (and for many other Toyotas as well).
Old 01-25-2010, 09:23 PM   #15
upgradedyaris
Drives: Yaris & Supra
'08 would work, you would not have an indicator light but CScott made a module for it. ;)
Duane
upgradedyaris is offline   Reply With Quote
Old 01-26-2010, 01:21 PM   #16
b_hickman11
Drives: 08 Sedan
My 2005 Taco had the same cruise as the 2010 Yaris so you could probably go to a junk yard and get one off of any Toyota you find.
Old 01-31-2010, 01:38 PM   #17
Flippy
Drives: Yaris Sedan 2008
Some of us are DIY idiots - I can hardly change a lightbulb but would be interested in the non-dealer route -
So I could buy the parts online - then pay a mechanic to install?
How much ballpark should this cost?
Flippy is offline   Reply With Quote
Old 02-06-2010, 11:36 AM   #18
t2mike2
Drives: '10 Yaris 3 DR - Carmine Red
ive been driving my 2010 Manual hatchback without the clutch switch. Its a little bit of a pain the first few times you accidentally hit the clutch and the rpms shoot through the roof, but after you remember that you just have to hit the brake to disable cruise first then it works fine.
So you dont really NEED to have the clutch switch. I jumped mine out with a spade connector i found. Fit perfect like it was made for it.
P.S. thanks again scott for your help.
~mike~
t2mike2 is offline   Reply With Quote
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
