![]() Drives: none Join Date: Nov 2009
Winter and Heater (A/C)
Hi,
has anybody noticed that when you have car with full load of passengers in winter, the heater doesnt blow warm air enough and the back windows get steam. Or if you try first at the cabin, windshield is on steam. (Hoping that summer will come soon) |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
Just moisture in the car... cant wait for summer to dry out my poor little hatch </3
-Jen <3 ![]() Quote:
yea same here, i just have a 2 year old in the back car seat in my sedan she fogs up the damn windows in the back i yell at her and say stop breathing lol (jk im not harsh)
Audio Junky
tell your passengers to stop breathing... hehe.. Yeah, I live in a very humid place, and having just one extra person in the car makes it difficult for me.
![]() ![]() Drives: 2010 Toyota Yaris Hatchback Join Date: Sep 2009
Roll down the windows and let some of that fresh winter air in
![]() That'll defog your windows real quick. |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
With the heat turned up, switch on the AC. This will de-humidify your environment while still providing heated air. Once all is clear, switch off the AC.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
Half a Bubble Off Plumb
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
actually its not the same. the defroster only partly uses the ac feature. pressing the button will allow for 100% Ac compressor. also with the ac on it allows u to set the blow mode to face (which i find helps the back windows alot more)
Just me $0.02....or with the exchange only about $0.019
![]() Drives: 2010 5dr hatchback manual Join Date: Feb 2010
Are you using recycled air or letting the flow through mode with your defrosters on. I find mine steam up if I am set to recycle the interior air. I also like to have the driver window cracked open at least a quarter inch. Both help with reducing the fogging effect. Turning the AC also helps quickly, but then your fighting the heater.
#10 | |
I see you are in Canada so it probably isn't an issue for you. When it is really hot in the summer I switch to the recycle mode for AC as it gets colder faster that way. Otherwise, I too prefer fresh air... unless fresh air is too hot to breathe.
I switch to Recycled air when I start to smell something foul IE a skunk or a smelly car in front of me it seems to keep the smell outside the car.
Doesn't the window fog up faster when you have it set to recycled air and defroster mode?
#14 | |
![]() ![]() Drives: Black 5-Spd Sedan S Join Date: Aug 2009
In the winter I usually use recirculate for the first 5 minutes of driving, then switch to fresh air when the engine is a little warmer and the windows are just starting to fog up. Technically recirculate (or blower fan turned off) should help the engine heat up quicker, because you're not pulling as much heat out of the coolant when you're heating up recirculated air, as opposed to much colder outside air, for example. |
#15 |
I keep it turned off for the first little bit till the engine's starting to warm up. Doesn't feel great to get in a cold car and just blow the cold air around.
#16 |
^^ there's that.
but the canadian yaris.. and i believe the cold weather packaged yaris also, have an electric heater to help the interior warm up faster. |
#17 | |
EDIT: and would we also not get a little bit of a toaster like smell. all electric heaters let off some sort of smell for the first little while
#18 | |
Is the cold weather package different than the all weather package? I just looked at my window sticker, and my "all weather guard" package has: Larger window washer tank with low level warning indicator lamp, heavy-duty heater, heavy-duty starter and rear heater duct. |
| heater control box issue | DevilGirl | DIY / Maintenance / Service | 12 | 01-08-2010 03:45 PM |
