Old 03-23-2010, 04:05 PM   #1
GrimlockGT
GrimlockGT's Avatar
Drives: 2009 3DR Blizzard Pearl CE
My car after TRD Springs and Sway Bar
Here are a few pictures of my car after I put on the TRD Springs and Sway Bar. I did the install by myself and the hardest part was the top nuts to remove the front spring assembly. I managed to do it without removing the cowl and wipers. I'm going to get a wheel alignment in a week or so, just to be safe.
2009 Blizzard Pearl 3Door Liftback
GrimlockGT is offline   Reply With Quote
Old 03-23-2010, 04:49 PM   #2
DARK AGE 53
Drives: 2009 Yaris Onyx
Car looks great , what was your total drop?
Later,
Al
DARK AGE 53 is offline   Reply With Quote
Old 03-23-2010, 05:24 PM   #3
ricktoyota73
ricktoyota73's Avatar
Drives: 2014 Yaris 3-Door
I just did the same thing and I'm diggin' it! I didn't measure but I think 1"-1.5" drop...looks like more than 1", but maybe not quite 1.5".
ricktoyota73 is offline   Reply With Quote
Old 03-23-2010, 05:37 PM   #4
GrimlockGT
GrimlockGT's Avatar
Later,
Al
Like RickToyota said, it was just over a 1" drop. I did before an after measurements for the front. I already had the rear springs off when I thought about measuring the rear.
Old 03-23-2010, 07:30 PM   #5
detroiter
detroiter's Avatar
Don't forget that it's going to drop more once the springs settle in. Expect another .5" or so.
Old 03-24-2010, 08:14 PM   #6
ricktoyota73
I think mine are settled now...it looks even better, so look forward to that ;)
Old 03-24-2010, 08:59 PM   #7
DARK AGE 53
Any rubbing, if there's a Michigan meet I hope to see your car....also, do you have a stock or aftermarket exhaust system?
Old 03-24-2010, 10:17 PM   #8
ricktoyota73
No rubbing even with 17" wheels, but have been solo in the car so far. That might change with passengers/gear, etc. I have a Megan Racing muffler and I think the pipe and axle beam make contact sometimes. I'm going to try some shorter rubber exhaust hangers to see if it solves the problem. Other than that, I'm good!
Parts Pro at Metro Toyota Kalamazoo, MI.
Old 03-25-2010, 06:06 PM   #9
Billiam
Drives: '10 White Yaris 4D LB
How's the ride quality with the TRD springs?
Old 03-25-2010, 06:19 PM   #10
XYaris
Drives: '09 Yaris LB
I have the same springs and sway bar along with 17's. Ive never rubbed. Also, look forward to an additional 1/2" drop as they settle.
Ride quality is def. firmer but I believe the springs are progressive, so that helps a bit. The 17's kill the ride much more than the springs.
XYaris is offline   Reply With Quote
Old 03-25-2010, 06:54 PM   #11
GrimlockGT
GrimlockGT's Avatar
Yeah, I have 17" x 7" rims with +42 offset, 205 40 17 tires and there is no rubbing. The car definitely handles better, but ride is a bit rougher. I like it, but my wife noticed a difference right away. The car bounces a bit, but that is due to the stock struts and shocks. Maybe next year I'll replace them.
Old 03-25-2010, 09:13 PM   #12
DARK AGE 53
GrimlockGT, what kind of front mud guards do you have on your car?
Old 03-25-2010, 09:30 PM   #13
GrimlockGT
GrimlockGT's Avatar
Factory Toyota ones. My car is the Base CE which only has the ones in front. The next model up comes with front and back.
My car is a Canadian model so there might be some differences. (like Blizzard Pearl paint )
Old 03-25-2010, 11:30 PM   #14
DARK AGE 53
I have factory Toyota guards but they don't look like yours, looks like the Canadian guards are different. Thanks
TRD Springs And Sway Bar ricktoyota73 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 09-19-2013 09:12 PM
Tokico Blues + TRD Springs &Sway Bar after 5k miles regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 12-18-2009 12:11 AM
FS NST 10%, SSK, TRD Sway and Springs ToyotaTEch21 Items for Sale by private party 10 08-20-2009 02:50 AM
Anyone install only trd springs and rear sway? AdeJong 03 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 08-13-2009 06:35 PM
TRD Springs Shocks and Sway Bars IN STOCK Sparks Toyota-TRD Sparks Toyota 0 03-12-2009 10:54 AM
